11-17-2014, 06:24 PM | #21 |
Re: How to check "roundness" of wheels?
As to the original question, how about a dial indicator from HF?
11-17-2014, 06:25 PM | #22 |
11-17-2014, 06:37 PM | #23 |
I was thinking the same thing. Does anyone know of a HF dial indicator that could be used on some kind of rack, post, jack, or ??????
Fred Kroon 1929 Std Coupe 1929 Huckster |
11-17-2014, 07:45 PM | #24 |
You could use wire pulling lube that the electricans use.will not contaminate the rubber.
MY PROBLEM CHILD! |
11-17-2014, 07:50 PM | #25 |
11-17-2014, 07:56 PM | #26 |
11-19-2014, 05:02 PM | #27 |
The HF dial indicator comes with a magnetic base and adjustable arm. It's not overkill, it is cheap and easy. No need to read in thousandths, just minimal variation.
11-19-2014, 05:31 PM | #28 |
Thanks JackA. Will have to try one of these. Just need something to play around with anyway.
11-19-2014, 05:32 PM | #29 |
But the bump I have that I am trying to fix happens at 15 to 25 MPH. Things are great at 40 to 50 MPH.
11-19-2014, 05:43 PM | #30 |
Any small pointer can be rigged up, such as a piece of stiff wire in a clamp laying on the floor. It you can't easily see it by eye, it will probably not be a problem. This can check it radially as well as laterally.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
11-19-2014, 09:14 PM | #31 |
One of the problems I see using a dial indicator is that the friction from the rubber tire will try to move the whole indicator throwing off any accuracy. The indicator would need a friction free wheel on the shaft that contacts the tire. whirnot's pointer idea is good. You'd be amazed what the eye can see. I can easily see .005" runout when using my lathe. I true spoke motorcycle wheels that go 100mph using a wire pointer with no problems. I doubt if even 1/16" (.0625') runout on the tire would be felt at 15 mph. I think things would get pretty bumpy at 1/8" (.125") to 1/4"(.250"). Nobody would even need their glasses to see that much runout.
