Old 11-12-2014, 03:34 PM   #1
John S
John S's Avatar
Default Roadster Windshield Glass Removal
How does the windshield glass come out of a 28-9 roadster frame? Or in other words, how does the frame come apart to remove the glass?
John
_________________________________
http://www.dmafc.com/
John S is offline   Reply With Quote
Old 11-12-2014, 08:44 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Windshield Glass Removal
I haven't done one, but there was a thread about it a few weeks ago. As I recall you just remove the hinge pivot studs then tap the top bar off the glass and lower frame.
Old 11-12-2014, 09:26 PM   #3
John S
John S's Avatar
I saw that thread and as I recall it was on a 30-31. I guess 28-29 is the same?
John
Old 11-12-2014, 09:32 PM   #4
Randy in ca
Randy in ca's Avatar
There are 2 screws on each side, above the pivot studs, that hold the top bar to the rest of the frame. After they're removed the top bar should lift up and out easily barring corrosion, etc.. The glass should then also slide up and out of the frame. Don't believe that the pivot studs need to be removed unless the threads are longer than they should be for some reason and are binding against the edge of the glass.
Randy in ca is offline   Reply With Quote
Old 11-12-2014, 09:38 PM   #5
John S
John S's Avatar
Mine has only what look like 2 flat rivet heads on each side, no screws. Maybe the slotted part was ground away at some point. As is most everything else on this car the windshield frame is a mess.
John
Old 11-19-2014, 09:59 AM   #6
John S
John S's Avatar
Default Re: Roadster Windshield Glass Removal
Well, with some drilling and e-z out work I was able to get the screws out and get the frame apart. Now to fix all of the holes drilled for snaps that are in the top front of the frame. Thanks for the help.
John
