11-17-2014, 07:03 PM | #1 |
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
Radiator drain petcock
The petcock has frozen up. I have sprayed some penetrating oil on the valve and I will let it set overnight. I notice the spring on the backside of the valve and want to make sure when I turn it, it's the normal righty tighty, lefty loosy. I need to drain the radiator and get anti-freeze in it. Can't find the turn direction in any of my books. I don't have a way or the weather to flush it yet.
Thanks
"Bullshit and Brilliance Comes with Age and Experience" "Hey Lady, ya wanna buy a Grit?" "If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers |
11-17-2014, 07:05 PM | #2 |
Re: Radiator drain petcock
It is supposed to turn either direction
You can also just unscrew it and work on the bench with it |
11-17-2014, 07:13 PM | #3 |
Thanks Mitch............
11-17-2014, 07:17 PM | #4 |
i see sarah is already being difficult... its one thing dating and another living together
11-17-2014, 07:27 PM | #5 |
Being made out of a "soft" metal, it also breaks off easy. Don't need to ask me how I know!
11-17-2014, 07:33 PM | #6 | |
I've learned to go where the advice is perfect when I'm on unfamiliar ground....I have even stopped now and then and ask directions. Although a soldier never gets lost, they only get......mis-orientated.
11-17-2014, 07:36 PM | #7 |
I have patience and all winter......come spring I want her to purr and perform.
11-18-2014, 04:40 AM | #8 |
I always use antifreeze year round. Water causes rust and plugged radiator tubes. Be sure to check your lower water pipe for deep pits. Mine developed a pin hole, and while climbing a long hill a year ago it lost the coolant and overheated. Luckily I had 3 gallons of water along, but overheats never helped an engine. I rechecked the head nuts the next day and found they had loosed up a lot from the overheat.
A 6" adjustable wrench works well to turn the tight drain cock. Be sure to poke a wire up the hole to be sure it's open and all the water has drained out. |
11-18-2014, 07:29 AM | #9 | |
11-18-2014, 07:37 AM | #10 |
topping off a quart wont do squat for the engine if the system is full of water... you would be better off just emptying the system till the weekend..
when all said and done the level should be about baffle level in the radiator... |
11-18-2014, 07:48 AM | #11 |
Didn't think it would really. The first thing I wanted to do was get it drained while the garage was heated but the peacock stopped me. I'll see if the penetrating oil did any good over night later.
11-18-2014, 12:20 PM | #12 | |
Bert's sold many dozens of engine blocks last year due to freeze cracks. |
11-18-2014, 12:56 PM | #13 |
From another newbie who just did the same thing a couple weeks ago...a few notes...
As Tom mentioned, you only need to turn it 1/4 turn for it to be wide open and 1/4 turn to close it.....I did not know that until I actually did it. I also went to the hardware store and bought a short length (about 5 feet) of 3/8 inch inside diameter rubber hose, this fit perfectly on the drain and was easily able to run it to a 5 gallon bucket.. Good luck. Nick |
11-18-2014, 04:18 PM | #14 |
BINGO!!!!!!!!!!!!!!!!! Peacock opened up and good anti-freeze began coming out. I closed it back up and gave a good sigh of relief.
11-18-2014, 08:07 PM | #15 |
Get a anti-freeze checker! Just because it has color does not mean it's good.
11-18-2014, 08:26 PM | #16 |
just dump it and refill with fresh you dont know how long its been in there..
11-18-2014, 08:29 PM | #17 |
Get new in the rad. No telling the acidity of the old stuff.
11-18-2014, 09:06 PM | #18 |
I will do a complete drain and refill tomorrow..............Thanks gents!!!!
11-18-2014, 09:22 PM | #19 |
Change it out 50 50 water and antifreeze. The problems people have with something as simple as the pet cock on the lower pipe. Amazing!
