Old 06-01-2010, 01:52 PM   #1
fordfixer
Default Gas gauge
Am working on a gas gauge that looks quite different than most. It has a single arm coming off of the side, instead of the wire coming down from between two pivot points. Is this a early 1928? It has the magnified lense, oval shaped. It was frozen tight, with carb cleaner and penetrating oil, I was abe to free it up nicely. This is the only one I have seen this way. I have worked on dozens of these. Jon
fordfixer is offline   Reply With Quote
Old 06-01-2010, 02:01 PM   #2
TK in LA
TK in LA's Avatar
Default Re: Gas gauge
Do you have a picture?
TK in LA is offline   Reply With Quote
Old 06-01-2010, 03:02 PM   #3
d.j. moordigian
d.j. moordigian's Avatar
It's sounds like a early 28, post a pic for a definite answer. Dudley
d.j. moordigian is offline   Reply With Quote
Old 06-01-2010, 03:27 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
It's an early 28 gas guage. I also have one, but the last time I looked for it I couldn't find it.
Old 06-01-2010, 06:31 PM   #5
fordfixer
Thanks for the pics Tom. That is it exactly. I guess I'm going to get this rebuilt very gently. Notice the spring type, on the back of the arm with the gauge strip. I wonder if this is for adjusting or to eliminate the bouncing effect.
Old 06-01-2010, 07:17 PM   #6
wrndln
Does anyone know how to free up the star shaped inner part to remove it in order to clean the lens. I have soaked it in carb cleaner for 2 weeks and it is still stuck tight. There is a thin plate that is rusted that surrounds the lens. Is it supposed to be black or plated nickel? Thanks for any help.
wrndln is online now   Reply With Quote
Old 06-01-2010, 07:59 PM   #7
glenn in camino
glenn in camino's Avatar
WOW, that's COOL. That's a 1928 part I've never seen before. Thanks for the pictures.
Old 06-01-2010, 08:41 PM   #8
Tom Wesenberg
Remove the rod and guage then slip the two sides that hold the rod over a pice of 1 x 4 board clamped in the vice. Now the face will up and I soak it with laquer thinner. Then you press the center tool down hard and turn CCW. This has worked for me when they are very tight.
Old 06-01-2010, 09:34 PM   #9
wrndln
Thanks if the info, Tom and Don.
Old 06-02-2010, 01:42 PM   #10
fordfixer
working on the one that Tom posted the pics. about. I also found it would not come loose. So I set it in the vise and sprayed carb cleaner on it. Then I use a o-ring pick to go into the threads and work ou the old gas as much as possible. Used more carb cleaner. I then used a pencil torch, to heat the outside of the gauge. It only has a flame about 3/8 inch long. When I saw the cleaner start to bubble in the threaded area, I then used the wrench. It turned out very easly. Hope this helps. I wouldn't use any bigger torch. It could ruin the gauge beyond repair.
Old 06-04-2010, 02:18 PM   #11
Model A Speedster
In an early '28 gas gauge, the little spring on the level indicator is supposed to hold the indicator lightly against the glass, thereby keeping the glass and the gauge clean.
Any car can drip oil, but for a real puddle, it takes a Model A.
Model A Speedster is offline   Reply With Quote
