06-03-2010, 08:46 PM | #1 |
Zmax?
Can you use zmax in a model a. I know it's supposed to be absorbed by engines and the a engine is very porous. Would it work? Has anyone tried it?
06-04-2010, 07:47 AM | #2 |
Re: Zmax?
I have never heard of that product. Do you have a link to a product description?
06-04-2010, 07:50 AM | #3 |
Re: Zmax?
Clean and proper weight motor oil will do a better job than any of those additives. I don't believe half the claims they make.
06-04-2010, 07:55 AM | #4 |
Re: Zmax?
zMax is a brand name, and they make several aditives for fuel and oil. I have seen it advertized by Carrol Shellby on TV. Just Google "zmax" and you can learn all about it.
That is an interesting question if zMax would be a benefit to the Model a engine. I personally use toady's modern detergent oil in my A engine, the oil and their additives (IMHO) are better refined than those from the early party of the 20th century. Maybe we will see some infor from a zMax user.
Ron/IA 1929 Fordor Steelback Hawk A Model A Ford Club http://hawkamodelaclub.org/ Last edited by Ron/IA; 06-04-2010 at 11:17 AM. |
06-04-2010, 10:33 AM | #5 |
Re: Zmax?
I put some in at the last oil change to get some Zinc into the mixture. It would take a carefully controlled trial to determine if it really helps. There is a company making a Zinc heavy oil (can't remember who) that claim the additives are a waste, and you need the Zinc rich oil.
06-04-2010, 10:40 AM | #6 |
Re: Zmax?
V4f |
06-04-2010, 11:03 AM | #7 |
Re: Zmax?
My only thought is; comparing today’s modern high RPM engines with the Model A engine is a real stretch. Much lower compression, much, much lower RPMs.
With that said, what great benefit would it achieve by adding very expensive oil additive to a Model A engine? I prefer to spend my $$ and use a top quality lubricant and be vigilant about changing the oil. I might add, I do not use an oil filter. My bottom line is I subscribe to the K.I.S.S. principle of keep it simple. Therefore one may do as he things best but the Cost/Benefit of ZMax doesn’t add up in a Model A , (IMHO) |
