05-30-2010, 06:36 PM | #1 |
which way does manifold clamp go??
hi, installing my manifold clamp, and not sure which way it goes! Les Andrew's book states the SMALL diameter side goes on the manifold.... but just playing with it, sure seems the LARGE diameter side would fit better around the manifold. I've had it installed before, and was just re-installing it after having the motor out, had not noticed the Les Andrew's instruction before. Maybe I've had it upside down all these years? :-)
05-30-2010, 06:59 PM | #2 |
Re: which way does manifold clamp go??
The nut MUST hit the convex side. So you are correct in thinking the large diameter hits the manifold.
05-30-2010, 07:02 PM | #3 |
thanks Tom (just putting the engine back in, crank and flywheel all balanced!). What do you mean by "nut must hit convex side..." ?
05-30-2010, 07:38 PM | #4 |
05-30-2010, 07:51 PM | #5 |
Re: which way does manifold clamp go?? - For Clarity
For clarity, the perimeter of the washer or "clamp" must contact the manifold flanges or ears. If you reverse it and the center of the clamp makes contact with the manifold flanges you are almost certain to snap an ear or two.
Oops! I need to read more carefully!!!
http://www.abarnyard.com/ Last edited by Marco Tahtaras; 05-30-2010 at 10:54 PM. |
05-30-2010, 08:42 PM | #6 |
If it's the muffler clamp, the large diameter goes up, around the manifold. Joe
1929 Tudor since 1962 Feather River A's |
05-30-2010, 08:46 PM | #7 |
I think he is talking about the exhaust pipe/manifold clamp.It will really only fit one way.I don't know what the book says,but if you fit it up there your eyes will tell you how it goes.
05-30-2010, 09:01 PM | #8 |
yep, talking about the manifold clamp to muffler.... Sorry for the confusion.
Thanks for clarifying, that must have been a typo in the Andrew's book. Sure didn't look right! :-) |
05-30-2010, 09:15 PM | #9 |
Joe & Keith explained it right, maybe this picture will help.
