Old 09-04-2022, 12:58 PM   #1
slatgrille
slatgrille's Avatar
Default How to preserve rubber seals
As my '29 RPU is almost finished, I noticed that the headlight bar fender seals are cracking and my hubcap O-rings have broken like an 'old rubber band'. These were all new within the past 1 1/2 years. Now that I have to replace the O-rings already, is there a way to prevent them from breaking again? Frustrating when they're so new!
Thanks for the help.
Craig
slatgrille is offline   Reply With Quote
Old 09-04-2022, 01:14 PM   #2
rust revival
Default Re: How to preserve rubber seals
Soak in glycerin every now and then, also works for old non cracked rubber
rust revival is offline   Reply With Quote
Old 09-04-2022, 01:30 PM   #3
Bob Bidonde
Bob Bidonde's Avatar
Those parts very likely sat in a warehouse and a dealer's shelf, so they were aged when bought them thinking they were new. Replace the hub cap o'rings with waxed string using as many turns necessary to tighten the caps.
Originally, the Model "A" did not have anything between the headlight bar and fenders. To protect the paint, I use clear plastic shipping tape trimmed to the footprint of the headlight bar. Be sure to have a good ground between the frame, the headlight sockets and the horn.
Bob Bidonde
Old 09-04-2022, 02:36 PM   #4
mcgarrett
Bob,
Where do you get waxed string?
mcgarrett is offline   Reply With Quote
Old 09-04-2022, 02:40 PM   #5
shew01
shew01's Avatar
Originally Posted by mcgarrett View Post
Bob,
Maybe something like this?
Livder 175 Yards 1 mm Waxed Polyester Cord Thread Bracelet Necklace String Wire for Jewelry Making Beading Crafting https://a.co/9BCBfSF
shew01 is offline   Reply With Quote
Old 09-04-2022, 03:18 PM   #6
slatgrille
slatgrille's Avatar
Thanks for the tips guys! Since the seals aren't original equipment, would the tail light bracket to rear fender seal also be an aftermarket 'thing'?
Old 09-04-2022, 08:00 PM   #7
norcalal
Taillight to fender seals never happened either
norcalal is offline   Reply With Quote
Old 09-05-2022, 07:44 AM   #8
Bob Bidonde
Waxed string is used on aircraft to tie the electrical wires in a harness. You can make some by pulling string on a candle. Heat the candle a tad to soften it. See this:
https://www.xsotica.com/natural-roun...iABEgKPy_D_BwE
Bob Bidonde
Old 09-05-2022, 09:53 AM   #9
katy
katy's Avatar
It's called "lacing".
Old 09-05-2022, 10:33 AM   #10
Flathead
Flathead's Avatar
I think those rubber parts come from China and the rubber used does not stand up to sunlight. I've had those hubcap rubbers do the same thing so I don't use them anymore.
Flathead is offline   Reply With Quote
Old 09-05-2022, 10:54 AM   #11
slatgrille
slatgrille's Avatar
Apparently they don't stand up to air either! My car is in a relatively dark garage all the time. 'Chinesium' at its finest....
Old 09-05-2022, 10:55 AM   #12
Tacoma Bob
Tacoma Bob's Avatar
Embalmers use waxed string. Might try looking up Mortuary Supplies. Don't ask me how I know.
Tacoma Bob is offline   Reply With Quote
Old 09-05-2022, 11:10 AM   #13
Stingray70
Stingray70's Avatar
Get a bottle of 303 Aerospace protectant. That stuff is amazing. Wipe it on rubber parts like that and it seems to extend their life considerably. For seals like in the OP, coat the new ones before installing.
1930 Standard Coupe
Stingray70 is offline   Reply With Quote
Old 09-05-2022, 11:11 AM   #14
Flathead
Flathead's Avatar
I won't ask what they use it for either.
Old 09-05-2022, 11:22 AM   #15
40 Deluxe
Chinese companies produce what the customer wants, just like companies everywhere. When the U.S. buyer wants the cheapest price, he gets the cheapest product. This is why your rubber seals crack so soon!
Old 09-05-2022, 02:27 PM   #16
Terry Burtz, Calif
Craig
The problem is that people who have these parts made do not specify what type of rubber should be used.
Anything exposed to sunlight should be made from EPDM.
Terry Burtz, Calif is offline   Reply With Quote
Old 09-05-2022, 04:35 PM   #17
Y-Blockhead
Y-Blockhead's Avatar
Some years ago, Dill had a recall of 2 million valve stems for tubless tires because they didn't mix in the UV "stuff" to protect them from the sun and the were cracking.
While driving to Oregon to visit my wife's parents we had a valve stem break off on the highway. We made it to a Performance Tire Store in Stockton, Ca. The manager was aware of the recall and replaced all of our valve stems for free.
It could have been worse but we were close to the off ramp for a rest stop.
