Old 02-07-2021, 12:45 AM   #1
RWnrh
Default Speedometer cable/speedometer noise
Working on a '36 Ford Tudor that has been in my wife's family since new. Noise from in back of the instrument panel and wild mph readings. Believe it is a speedometer cable (it stopped when I unscrewed it from the speedometer). Any recommendations for a good person in the Dallas/Ft. Worth area to work through and solve this issue? Thanks in advance.
RWnrh is offline   Reply With Quote
Old 02-07-2021, 04:32 AM   #2
deuce lover
deuce lover's Avatar
Default Re: Speedometer cable/speedometer noise
IMO your speedometer needs service.John Wolf & Co in OH is one I can recommend.Reasonable and fast service.
deuce lover is offline   Reply With Quote
Old 02-07-2021, 06:02 AM   #3
tomkc1
tomkc1's Avatar
When I had that problem with my '34 10 years ago I undid the cable as you have done and put a few drops of 3 in 1 oil in. It solved my problem.
Tom
tomkc1 is offline   Reply With Quote
Old 02-07-2021, 10:02 AM   #4
51504bat
51504bat's Avatar
I had an excellent experience with Rusty at Speedometer Service in Colorado Springs. I spoke with him several times on the phone. He sold me a NOS unit with lens for my '54 Ranch Wagon. He checked it all out before shipping it since it had been sitting on the shelf for a while. Fair price, reasonable shipping AND he shipped it to me before I sent him a check.
https://www.speedoservice.com/
(719) 632-3165
51504bat is online now   Reply With Quote
Old 02-07-2021, 10:09 AM   #5
shoe box Jack
I did the same as Tom worked for me. Jack
shoe box Jack is offline   Reply With Quote
Old 02-07-2021, 10:22 AM   #6
19Fordy
19Fordy's Avatar
First try supporting the cable with a wire tie so that if feeds 90 degrees into the speedo head with a gentle curve instead of dropping down under its own weight.
Old 02-07-2021, 10:47 AM   #7
joe 1950
joe 1950's Avatar
Like tomkc1 said the most important part is making sure that the cable is clean and lubed take and pull the cable out clean it and lube it with a very thin lubricant try this first good luck
joe 1950 is offline   Reply With Quote
Old 02-07-2021, 03:47 PM   #8
Ggmac
What Joe50 says . Remove , just pull the cable center out , lube , i use white lithium ( live in s Florida) reinstall . Itll usually go away . Also hang it like 19forty says , you want a straight shot as possible for the cable to enter the rear of the speedo
Ggmac is offline   Reply With Quote
Old 02-09-2021, 09:19 PM   #9
RWnrh
My thanks to each of you for your suggestions. I'll give it a try and then call in the cavalry.
Old 03-10-2021, 09:03 AM   #10
RWnrh
I talked with Rusty in Colorado Springs, but he did not have the parts for the Delco unit that we have; however, he directed me to John at DeLuxe Speedometer and Cable Service in Denver. I've contacted him and he can help in the rebuild (which I've determined that I need through 3rd party testing) of the speedo. I'll report back on the outcome.
Old 03-15-2021, 07:05 AM   #11
papanick
Hi the speedometer needs a good cleaning and serviced. When it get dry in side it will make that noise and then when it get to bad it will lock up and damage the cable. If you need to have it done let me know. papanick [email protected]
papanick is offline   Reply With Quote
