04-04-2021, 06:09 PM | #1 |
My Zenith
Nice day today, was going to gas up & the gas gauge show 0. Got it started while running I notice gas dripping to the floor. Got a mirror & seen gas leaking from a small hole on the bottom ?? Float stuck or not adjusted correct ? As always looking for help .
04-04-2021, 06:58 PM | #2 |
Re: My Zenith
Could be the float stuck. Did you run the carb dry at the end of the last drive?
04-04-2021, 07:33 PM | #3 |
Re: My Zenith
There can be a little flake of rust or other crud that is stuck in the float valve. Run the carb dry as Bob said and then turn the gasoline back on. The valve will be fully open and the gasoline can possibly flush the crud out. It if continues to leak, you will have to take the carb apart to check the float valve and possibly replace it. While you are in there, shake to float to see if it has gasoline in it which would indicate that it has a leak and needs to be replaced.
04-04-2021, 08:40 PM | #4 |
Re: My Zenith
Good advise running it dry & or taking it off to check the float. What about a inline filter between the shut off valve & the carb ??
04-04-2021, 10:23 PM | #5 | |
Re: My Zenith
It might not be a bad idea to take your carb apart and see if there is rust within on the castings. I've found quite a bit can build up on the inlet fitting, the interior of the chamber the carb screen fits in, and also in the bowl itself. An inline fuel filter won't help you with that. You may need to let the parts dry out completely to see it since rust darkens with liquid. EvapoRust or Rust911 to the rescue! And don't forget to chase all the air passages with wire while you have it apart. If you do end up replacing the float valve, think about spending a couple of extra bucks on the neoprene-tipped version, seems to seal a bit better. Another way (very old school, the way my Dad taught me) to check the integrity of the float itself is to immerse it into a saucepan of boiling water. Bubbles indicate a leak... (don't do this on a "modern" plastic float, this is for brass/copper floats only). JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
