Old 01-21-2019, 09:57 PM   #1
Fourdy
Fourdy's Avatar
Default Stock oil filter?
I am preparing to start my engine for break-in and have a question about the filter. The filter body has a tight rubber seal on the top and bottom that appears to seal against the inside tube. I have a new seal for the lid but don't know if anything more is required as far as seals go.
Thanks and anxious for the help.
Fourdy
Fourdy is offline   Reply With Quote
Old 01-21-2019, 11:03 PM   #2
41ford1
41ford1's Avatar
Default Re: Stock oil filter?
That is all you need. Just make sure the cover and body surfaces are clean. Remove the old gasket from the cover and install the new one in its place.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 01-21-2019, 11:24 PM   #3
Fourdy
Fourdy's Avatar
Thank you for your reply. Everything is all cleaned up and ready to go then.
Fourdy
