Old 04-05-2018, 12:42 PM   #1
TonyM
TonyM's Avatar
Default Over Drive Rebuild Needed
My friend has resurrected a 1972 Ford F-100 with V-8, bringing it back to life after a long slumber and a near death experience. It is now streetable.
He is interested in rebuilding a Borg & Warner overdrive unit for this truck.
Can anyone on the forum refer my friend to a reputable vendor in the Chicago/Northwest Indiana region who can rebuild this unit?
Thanks.
TonyM is offline   Reply With Quote
Old 04-06-2018, 12:41 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Over Drive Rebuild Needed
The T-85-N with R11 overdrive is not all that different from the old R10 overdrives used in the 8BA flathead era. The R11 is a 4-planet gear type instead of 3 but it still works the same way and has the same basic internal and external components. The key will be finding a shop that has the tech publications to cover them and some experience with the Borg Warner electric overdrive wouldn't hurt. A good core may be a job to find but get the best one available if still looking.
Just to add. I believe that the truck unit has a fixed output yoke. It requires a telescoping type drive shaft if I remember correctly.
Old 04-08-2018, 07:13 PM   #3
KULTULZ
KULTULZ's Avatar
Post Re: Over Drive Rebuild Needed
Give these guys a call- http://www.nationaldrivetrain.com/index.php
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 04-18-2018, 12:15 AM   #4
TonyM
TonyM's Avatar
Thanks to all who responded.
TM
