Old 10-25-2023, 10:53 AM   #1
dono50
dono50's Avatar
Send a message via MSN to dono50
Arrow Question on 6v to 12 volt conversion
My existing-setup ….wire from ignition switch runs to the original Ford resistor on inside firewall then to the + side of the coil. I’m using a new Beru German 3.3 ohm VW coil so no external resistor is needed.
My question, is this setup correct or should I eliminate the original Ford resistor .
Early 47 Ford with an 8BA engine
dono50 is offline   Reply With Quote
Old 10-25-2023, 12:38 PM   #2
JayChicago
JayChicago's Avatar
Default Re: Question on 6v to 12 volt conversion
3 ohm thru the coil is sufficient resistance in itself. Resistor should be by-passed.
JayChicago is offline   Reply With Quote
Old 10-25-2023, 05:33 PM   #3
dono50
dono50's Avatar
Thanks, Jay. That’s what I’ll do.
Bob
