11-19-2021, 10:12 AM | #1 |
Heavy Oil & Shifting
I don't want to beat a dead horse over this as I've brought this up before a few times.....A question just occurred to me, though. Does heavy transmission oil in the winter time cause the gears to slow down quicker or faster in between shifts? I thought it would slow them down quicker. I put in 600W from Snyders and it's cold in Iowa now. Up-Shifting has become difficult and unpredictable. Down-Shifting is fine.
11-19-2021, 10:42 AM | #2 |
Re: Heavy Oil & Shifting
Yes, heavy oil wil slow the gears quicker. You would probably do good using a multi-grade. I use Lucas 85w-140 with good results.
Ruth "Sometimes you really DO need to read the whole thread" |
11-19-2021, 11:53 AM | #3 |
mix half 85wx140w with half STP, done this for years and use it in diff. and trans...shifts without grinding
11-19-2021, 11:58 AM | #4 |
That's 2 votes for the 85W-140. I've been thinking about changing that out. With that do you up-shift fast or slow? Double-Clutch?
11-19-2021, 04:23 PM | #5 |
Three votes for 85W-140. Ford recommended 10% kerosene in the transmission oil for cold weather. You can go that route but then you have to change back in warmer weather. Plus the modern transmission oil is better for the transmission. The transmission and rear end will last longer. The modern oils have additives that maintain the oil film.
11-19-2021, 05:42 PM | #6 |
11-19-2021, 06:46 PM | #7 |
10% is one part in 10. So 10 ounces of oil would have 1 ounce of kerosene added to it. 20 ounces of oil would have 2 ounces of kerosene added to it. I think the transmission holds one pint, which is 16 ounces. So you would add 1.6 ounces of kerosene to the transmission for cold weather. A little less than 1/4 cup. I don't think the 10% is very critical so anywhere near that amount would probably work.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 11-19-2021 at 06:51 PM. |
