Old 05-27-2021, 07:09 PM   #1
mgambuzza
mgambuzza's Avatar
Default Check those belts
Although I've already put over a 100 miles since buying my Model A in October, one item I never checked until recently was the fan belt - DISASTER waiting to happen. As seen in the pictures below it would be just a matter of time before I would've been stranded. Ordered a couple days ago from Brattons, and today I'm good to go, and much better off than I was or would've been.
mgambuzza is offline   Reply With Quote
Old 05-27-2021, 07:15 PM   #2
Gene F
Gene F's Avatar
Default Re: Check those belts
I date the back of mine with a silver sharpie. Time flies faster than a radiator fan. LOL
Old 05-27-2021, 09:40 PM   #3
J Franklin
J Franklin's Avatar
A lost belt should never strand a model a driver, you'll just get home a little later than you thought. Your car will run a long time without a belt except in stop and go traffic.
J Franklin is online now   Reply With Quote
Old 05-27-2021, 10:12 PM   #4
ursus
In many parts of North America, the fan belt could be removed in November and replaced in April, with no loss of cooling capacity, a faster warm-up, and at least 1 more horsepower. Just saying,...
Old 05-27-2021, 10:20 PM   #5
Synchro909
Synchro909's Avatar
Just before we left on one of our long tours, I noticed the belt was like that. I was about to replace it but didn't - I left a new one on the floor in the back along with a spanner. It finally delaminated enough to cause a ruckus under the bonnet 2,500 miles later. When we arrived at the National Meet, there was a guy who had driven over 2,000 miles with no working water pump. The car ran a little warmer than usual but he stayed on 50 mph or more without damage to the car. If the belt breaks, it is possible to drive on except in stop/start traffic as has been said. The other thing you would lose is power output from the generator. If you don't use the starter or lights, you can drive a LONG way on what is in a good battery.
Old 05-28-2021, 11:21 AM   #6
HD Rider
A friend once lost his belt on a trip from Stockton Ca to Reno NV for Hot August Nights. He used his wife's pantyhose to make it over the mountain into Reno. That was on a SBC powered pickup.
HD Rider is offline   Reply With Quote
Old 05-28-2021, 12:37 PM   #7
McMimmcs
McMimmcs's Avatar
I don’t think they even sell panty hose now.
Old 05-28-2021, 12:38 PM   #8
McMimmcs
McMimmcs's Avatar
Very good to know, never heard that before! Thanks
Old 05-28-2021, 12:39 PM   #9
McMimmcs
McMimmcs's Avatar
And after you date it, what next?
Old 05-28-2021, 12:50 PM   #10
critter
Wouldn't have too much faith in the panty hose as a belt. Tried it and it didn't work for me,
critter is offline   Reply With Quote
Old 05-28-2021, 06:56 PM   #11
Gene F
Gene F's Avatar
I start looking at it a bit more closely in the early months of year 4. If I have a maintenance project going from there then I change it. They last a long time. Not a lot of pull on them, and I tend to drive my car every few weeks during the summer, and take it out, or warm it up 3 or 4 times during the off-season.
Old 05-28-2021, 07:45 PM   #12
WHN
Model A’s like the Model T use a siphon cooling system. Pump is there to help, the siphon moves most of the coolant.
Old 05-29-2021, 03:59 AM   #13
johnbuckley
johnbuckley's Avatar
...... Your car will run a long time without a belt except in stop and go traffic.
Really? I always assumed a non-revolving water pump would have restricted the flow too much .
Old 05-29-2021, 10:42 AM   #14
J Franklin
J Franklin's Avatar
I drove about 65 miles without fan belt once and didn't overheat. Water seems to get where it wants to go.
Old 05-29-2021, 11:24 AM   #15
katy
katy's Avatar
It depends on the design of the pump, Model A pumps are pretty low tech design.
Old 05-30-2021, 02:36 PM   #16
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
So, what did they do to keep the battery up? Must of charged it frequently?
Old 05-30-2021, 02:45 PM   #17
J Franklin
J Franklin's Avatar
URSUS was referring to cooling capacity.
