06-14-2020, 07:21 AM | #1 |
Con Rod Nuts
I pulled the oil pan to check/adjust bearing clearance. The nuts on there are pretty chewed up so I have a set on new nuts and cotter pins. When reassembling, do you torque the nuts to 35ft/lb and then tighten more to line up the hole for the cotter pin?
06-14-2020, 09:12 AM | #2 |
Re: Con Rod Nuts
the original fasteners and cotter pins? yes
06-14-2020, 11:02 AM | #3 |
Re: Con Rod Nuts
This is kinda new to me. I am doing both the engine in my Huckster and a spare engine that I have. The spare engine has the chewed up nuts that look original. All rods were .001 to .0015 so I left clearance as is. I only replaced the nuts with new nuts and cotter pins from either Bert's or Snyder's (Cat't remember). The Huckster engine clearance was .002 to .003 so I went ahead and took out shims to get to .001 to .0015. It has a longer castellated nut that looks much more substantial than the stock nuts so I reused them.
All the rod babbits look great in both engines. Next I will tackle the mains. BTW spare engine oil pan had no sludge the Huckster had very little sludge. I think that is a good thing. Last edited by DBSHELTON; 06-14-2020 at 11:08 AM. |
06-14-2020, 11:31 AM | #4 |
Re: Con Rod Nuts
The hydrodynamic principle is fixed at .001 per inch of shaft diameter this clearance allows the oil to support the crankshaft.Using modern diesel grade engine oil with higher load characteristics aides the principle. When using the stock model a crankshaft (non counterbalanced,but dynamically balanced) the torsional vibration at high rpm causes as much as .001 flex in the crankshaft,accelerating bearing wear.
06-14-2020, 11:43 AM | #5 |
Re: Con Rod Nuts
If at 35 the nut only has to move a small amount to get the cotter pin in, then yes I would turn till it goes in. If you can's see the hole then I sand down the nut and try again. Yes it is bit more work, but as the studs can't be replaced and once the threads are pulled, the rod is junk.
For sanding down the nut; I use 400-600 grit paper on a flat hard surface. Pulling the nut across it for example 3 times, turn 180 and 3 more times then test fit. Repeat as needed, but as you get close reduce the number of strokes across the paper.
I know the voices aren't real but damn they have some good ideas! |
06-14-2020, 03:19 PM | #6 |
Re: Con Rod Nuts
06-15-2020, 03:51 PM | #7 | |
Re: Con Rod Nuts
06-14-2020, 03:20 PM | #8 |
Re: Con Rod Nuts
I usually tighten them to 30# and twist until the cotter fits. That ends up about 35-40#. If I need to sand a nut I set the paper on sheet of glass and then measure to make sure they were sanded square.
I also try my best to keep the 2 shim packs the same thickness. If they don't want to peel apart I sand them and measure them to make sure they are sanded evenly. I also like to set the clearances [rod and main] at .0015" [ a bit tighter on the rear]. |
06-14-2020, 06:01 PM | #9 | |
Re: Con Rod Nuts
As for fitting the split pin, I go along with those who use modern self locking nuts and no split pins.
06-14-2020, 07:01 PM | #10 | |
Re: Con Rod Nuts
06-14-2020, 11:14 PM | #11 |
Re: Con Rod Nuts
OK, who has a spanner that size???? That converts to 15.08 mm. That is only 0.003" over 15mm. It would just take a lick to get them to 15 mm and every decent set of metric spanners has a 15mm.
06-15-2020, 10:22 AM | #12 |
Re: Con Rod Nuts
Being that 15mm is so close, try a few different 15mm wrenches or sockets, you may find one that fits snugly, not too tight, not too loose.
06-15-2020, 12:16 AM | #13 |
Re: Con Rod Nuts
Check out Metwrich, they fit standard and metric, they fit loosely but instead of rounding the corners they grab the flats. Best money I've spent on tools !
06-15-2020, 04:41 AM | #14 |
Re: Con Rod Nuts
06-15-2020, 05:17 AM | #15 |
Re: Con Rod Nuts
It is "Metrinch spanners". I have never tried them, though
SAJ in NZ |
06-15-2020, 07:50 AM | #16 |
Re: Con Rod Nuts
Sorry for the spelling, thanks SAJ ! Metrinch
06-15-2020, 01:27 PM | #17 |
Re: Con Rod Nuts
06-15-2020, 03:57 PM | #18 |
Re: Con Rod Nuts
Cotter pins do not hold torque.
06-15-2020, 09:01 PM | #19 |
Re: Con Rod Nuts
Now fighting chewed up square main bolts. God I hate this crappy design!
06-15-2020, 09:13 PM | #20 |
Re: Con Rod Nuts
