09-22-2020, 01:19 PM | #1 |
Ignition Switch
Just purchased a 1930 Model A Fordor with no starting switch key. It's a pop out switch with a code no 874 stamped on the side of switch cylinder. Local locksmith with no luck.
09-22-2020, 01:34 PM | #2 |
Re: Ignition Switch
Dick Crabtree restores the popouts and can cut keys. A and L cuts keys.
Use graphite lock lube. At the start of this section is a listing of services and web sites where you will find both. |
09-22-2020, 02:07 PM | #3 | |
Re: Ignition Switch
He did a rebuilt pop-out switch and original key for me. Works great. He also runs ads on ebay all the time.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!" |
09-22-2020, 10:00 PM | #4 |
Re: Ignition Switch
Lucky you. You have an original switch. Let Dick Crabtree get it right for you.
09-23-2020, 06:39 AM | #5 |
Re: Ignition Switch
Where are you located |
