Old 04-29-2020, 07:31 AM   #1
rockfla
rockfla's Avatar
Default Gas gauge liquid
Who would be best supplier for the Red gas gauge liquid OR Is there a formula of ingredients to make your own???
Thanks
Old 04-29-2020, 07:58 AM   #2
hotrodcbx
Default Re: Gas gauge liquid
Mac's old Ford parts has the liquid. I bought some last year and my gauge works well, only problem with their liquid is I notice the red dye used has faded a fair bit in the last few months..I believe Mac's has relocated to Florida from New York..
hotrodcbx is offline   Reply With Quote
Old 04-29-2020, 08:52 AM   #3
deuce lover
deuce lover's Avatar
Here is a thread on this subject
https://www.fordbarn.com/forum/showt...s+gauge+liquid
deuce lover is online now   Reply With Quote
Old 04-29-2020, 09:56 AM   #4
earlyride
earlyride's Avatar
I use red gauge oil, purchased at graingers. it has a sp of .826 not sure if that is ideal, but it works for me. I bought it quite a few years ago, but it should still be available from them
earlyride is offline   Reply With Quote
Old 04-29-2020, 09:57 AM   #5
rockfla
rockfla's Avatar
Thanks hotrodcbx & Sheldon, I seemed to remember that past post, but hadn't had the time to dedicate to looking!!! NO excuse for lazy!!!
Old 04-30-2020, 05:02 AM   #6
tomkc1
tomkc1's Avatar
How difficult is it to add the liquid? Does the whole thing have to be taken apart? I don't suppose there is a youtube video on it. Tom
tomkc1 is offline   Reply With Quote
Old 04-30-2020, 06:35 AM   #7
deuce lover
This is how I do it.Remove the speedometer,which gives you easy access to get to the gauge.Remove the air line then remove the gas gauge then clamp (the hex part in a vise).Make sure gauge is level.Add red fluid until it reaches the bottom line(empty) in the back hex where the air line was connected.If the fluid does not come thru from the back, the line is plugged and gauge needs servicing.
Old 04-30-2020, 06:44 AM   #8
FrankWest
FrankWest's Avatar
the top of the gauge tube is open, just eye dropper the fluid in.
FrankWest is offline   Reply With Quote
Old 04-30-2020, 06:47 AM   #9
FrankWest
FrankWest's Avatar
Check with renardscorner. https://rennerscorner.com/index.html
I know a guy that is tied of messing around with the gauge and stuffed a red pipe clean down the tube to simulate a full tank.
Thread Tools
Display Modes
