01-08-2020, 11:33 PM | #1 |
hoping I have a single disc clutch
I will be removing the starter from our early '28 Coupe tomorrow to get it rebuilt. The engine block has been replaced at some point with a '30 model block. I hope the early multi-plate clutch was swapped for a single disc when the engine block was changed. I will be looking, trying to figure out which I have while I'm under the car. I have the floor boards out now.
The clutch works well but I'm thinking about when/if the time comes for replacement $$$$$. |
01-08-2020, 11:56 PM | #2 |
Re: hoping I have a single disc clutch
If you have the floor boards out you should be able to tell pretty easily if you pull the inspection cover off the bell housing.
The Master Cylinder Enjoying life at the beach in SoCal... |
01-09-2020, 10:29 AM | #3 |
Finding multi-plate clutches is pretty rare. Most didn't last very long and the Ford dealers followed the service bulletin for replacement.
01-09-2020, 10:57 AM | #4 |
