10-28-2020, 08:07 PM | #1 |
1936 water pumps
Has any replaced the original water pumps with the new pumps advanced impellers in them. I was wondering if you noticed a big difference in temperature and solving over heating problems.
10-28-2020, 08:15 PM | #2 |
Re: 1936 water pumps
From Skip. Yes but temp stayed the same but I was not having an overheating problem.
10-28-2020, 08:26 PM | #3 | |
I've sent Skip (George) numerous pumps and can't say enough good about the man and his workmanship. However, after installing MANY of his pumps and noting NO difference in operating temperatures, well, to me that indicates they don't in fact make a difference on a finely set up flathead. If you're having issues and don't want to tackle the underlying cause(s), my "go to" would be George hands down before any other.
10-29-2020, 08:58 AM | #4 |
Thank you KiWinUS and Kube for your answers.
I was just wondering if they made a difference and they do According to the situation involved. You said it all.Thank you,Blast |
10-29-2020, 05:46 PM | #5 |
Skip uses a modern seal in the 36 type pumps. This allows him
to maintain closer clearances which increases the pump pressure. This results in almost double the flow. G.M.
www.fordcollector.com |
10-30-2020, 05:27 AM | #6 |
10-30-2020, 07:42 AM | #7 | |
10-30-2020, 12:14 PM | #8 |
Another option for the early pumps, are the truck pumps. The impeller is longer.
According to Ford, the head mounted truck pumps are 40 gpm @ 3600 rpm. The car pumps are 25 gpm and all the block mounted, are 45 gpm. G.M. do you make impellers for the truck pumps, too?
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
10-30-2020, 12:34 PM | #9 | |
pumps produced 55 gals in 5 minutes at water pump test machine speed and after machining the bodies and Skips new impellers they produce 110 gallons in 5 minutes on the 36 pumps. G.M.
10-30-2020, 08:10 PM | #10 |
G.M, The pumps I fitted are all brand new with modern sealed bearings, improved impellers and new cast iron body castings. Skips pumps are remachined original housings with his new improved parts fitted. Regards, Kevin.
10-30-2020, 09:30 PM | #11 |
I was assuming you had a set of SKIPS pumps. G.M.
