Old 10-26-2020, 08:59 PM   #1
grumpys hot rods
Angry Engine Problem
I purchased this engine 5 years ago. A 49-53 engine. Have had running on an engine stand.
Starts and runs ok 19in vacuum. When I rev up the engine, It starts running bad. Pull spark plugs and the electrode is shut. Looking thru spark plug hole
Can see where the valve has been hitting the spark plug.
CHAMPION J12YC AND AUTOLITE 216
Wrong Spark Plugs?
grumpys hot rods is offline   Reply With Quote
Old 10-26-2020, 09:05 PM   #2
Bill OH
Default Re: Engine Problem
Cast iron heads use Champion H10 or equal.
Bill OH is offline   Reply With Quote
Old 10-26-2020, 10:11 PM   #3
tubman
tubman's Avatar
"J" series plugs are too long.
Old 10-26-2020, 10:20 PM   #4
cadillac512
cadillac512's Avatar
I believe the "J" series threads are ok for clearance...actually a bit shorter than the correct H10 Champion threads...BUT the "Y" suffix means extended tip and that may be a problem as the valve opens enough to hit.
Are the Autolite 216's being hit as well? They should be ok with a stock head unless the cam has a LOT of lift.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 10-27-2020, 12:08 AM   #5
deuce_roadster
deuce_roadster's Avatar
Also, do you know if the heads have been milled, moving the plugs closer to the valves?
Old 10-27-2020, 07:43 AM   #6
grumpys hot rods
The Autolite 216 Plugs are also hitting. I'm going to try 216 with two washers and see if that works.
I tried to measure the valve lift. The valve comes real close to the cylinder head.
I'm thinking that the cylinder heads were milled a lot.
And add to the aggravation I have sold this engine to a friend.
Old 10-27-2020, 07:47 AM   #7
Ol' Ron
Ol' Ron's Avatar
Try an extra gasket. not the best idea, but should clear the valves. You'd have to mill the heads quite abit for the valves to hit the plugs, sounds like an aftermarket cam.
Gramps
Old 10-28-2020, 08:23 AM   #8
grumpys hot rods
I measured the exhaust valve lift with a dial indicator this morning.
I have .410 lift at that valve. That's a lot.
Checked flathead cam specifications and found the aftermarket cam with .400 Isky Jr
Going to try two washers this morning. Wish me luck
This is why you should check A camshaft.
Old 10-28-2020, 09:39 AM   #9
Phil Gillespie
Phil Gillespie's Avatar
You also can try non projected spark plugs from NGK they may work.
Used these with Edelbrock heads when I had contact with exhaust valve to original projected plug.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 10-28-2020, 12:19 PM   #10
Ol' Ron
Ol' Ron's Avatar
The 00jr cam will have only 375/380 lift. The 400 jr has aprox 390 ;ift, and varies abit depending who grinds them. The one I used in the stock car cam from Isky I hope.
Old 10-28-2020, 07:38 PM   #11
Bored&Stroked
Bored&Stroked's Avatar
What is also concerning is that it starts and idles just fine . . . which means the valves are not hitting the plugs.
Then you rev it up and the plugs get whacked and closed. If this is the case, then there may also be an issue with the valve springs . . . as the cam lifts what it does all the time and the valves should hit the plugs at any RPM - not just higher RPM . . . unless the valves are "floating".
If you're floating the valves when you rev it up, then there is nothing you can do to "fix it" with a different plug - the valvetrain is not setup correctly and the end result is too little spring pressure.
Old 10-28-2020, 08:08 PM   #12
slowspoke
Could an incorrect valve lash result in this issue?
slowspoke is offline   Reply With Quote
Old 10-28-2020, 08:13 PM   #13
Bored&Stroked
Not really as the most common valve lash issue is TOO much of it.
Also, typical valve lash values for performance cams are about .015, so it is doubtful that it is just a bit too tight and causing this.
Obviously the chambers are really close to the valves (probably too close), but he may also have valve spring pressure issues.
Old 10-28-2020, 10:03 PM   #14
Ol' Ron
Ol' Ron's Avatar
I ran stock springs on most of the L-100 builds, with a .060" shim. thid brought the installed spring pressur up to about 50lbs. The engines run up to5K with no problem. Installed in a street engine that rarely sees 4K. However, you might not get away with it with the 400jr.
Gramps
