Old 10-27-2020, 09:34 PM   #1
samsonized
Default rear end identification
i have a rear end in my 35 cabriolet that is not a 35 but rather a 37-40 how do i tell what year it is.
samsonized is offline   Reply With Quote
Old 10-27-2020, 09:36 PM   #2
JSeery
JSeery's Avatar
Default Re: rear end identification
Well, if it has the original backing plates, 37-38 were cable brakes and 39-40 were hydraulic.
Old 10-27-2020, 09:37 PM   #3
samsonized
nope juice brakes 46-48 backing plates
Old 10-27-2020, 09:41 PM   #4
JSeery
JSeery's Avatar
Don't think there is a lot of difference in the axles themselves. What are you attempting to figure out?
Old 10-27-2020, 09:43 PM   #5
samsonized
i would just like to know for maintenance in case there is a different in bearings or stuff like that
Old 10-27-2020, 09:43 PM   #6
Bursonaw
Bursonaw's Avatar
A picture would be helpful.
Sent from my iPad using Tapatalk
Bursonaw is offline   Reply With Quote
Old 10-27-2020, 09:45 PM   #7
samsonized
ill try to post one
Old 10-27-2020, 11:44 PM   #8
ford38v8
ford38v8's Avatar
Here's a link that will help you identify what you have.
http://goldengatev8.org/images/Stree..._magazine.html
Alan
Old 10-28-2020, 12:30 AM   #9
deuce lover
deuce lover's Avatar
35-36 radius rods which have the spring hangers attach to a bracket towards the end nearest the backing plates on the axle tubes.37-40 has a solid driveshaft so there is a grease zerk on the torque tube to service the bearing.
Old 10-28-2020, 07:30 AM   #10
samsonized
thank you so much is there an outword resistance between teh 37-38 and 39-40?
Old 10-28-2020, 07:30 AM   #11
samsonized
sorry outward appearance
Old 10-28-2020, 07:56 AM   #12
hop up
hop up's Avatar
Mike it would just be the rearbones that Deuce Lover mentioned as the 35 36 mounted on the axle and later would be mounted on the ends by the backing plates.
Wanted flathead speed equipment Thanks
hop up is offline   Reply With Quote
Old 10-28-2020, 07:58 AM   #13
samsonized
i know it is a 37-40 but is there a way to tell if it is solid driveshaft or hollow driveshaft without taking it apart
Old 10-28-2020, 08:03 AM   #14
hop up
hop up's Avatar
No easy way of doing that I can think of ? Maybe pull off the speedo housing on the tube and scope it
Old 10-28-2020, 08:13 AM   #15
samsonized
had not thought of that i have a scope is it obvious the difference between the hollow and the solid at the front of the tube
Old 10-28-2020, 09:01 AM   #16
JM 35 Sedan
JM 35 Sedan's Avatar
*Note....not all '37's (or '38's) left the assembly plants with a solid driveshaft, center of driveshaft bearing, and zerk grease fitting in center of torque tube. These were transition years between tubular vs. solid driveshafts. The additional things to look for on '37-'40 rear axles would be that the rear radius rods/bones attach by the two lower backing plate bolts, and the spring hangers are integral parts of the axel housing assemblies instead of being attached to the back of radius rods/bones as '35-'36 were. So, the rear end "assemblies" from '35 to '40 (+ '41 PU's) are for the most part, interchangeable.
John
Old 10-28-2020, 09:32 AM   #17
deuce lover
If it has the zerk fitting it is a solid shaft
Old 10-28-2020, 03:14 PM   #18
ford38v8
ford38v8's Avatar
No difference apparent on the outside. Inside, the only difference being the axles teeth changed from 18 to 16, and the matching Spider gear. Those sets are interchangeable. Pull up the link I posted previously for pictures and text.
Alan
Old 10-28-2020, 04:36 PM   #19
samsonized
thanks to everyone for their help
Old 10-28-2020, 05:31 PM   #20
bobH
There's the 10-spline vs 6-spline pinion deal, which I didn't notice as being mentioned. I opened what I think was a 37 recently, which had the 37-up spring hangers, but had the hollow-tube d/s (which many people associate with 35-36), and it had a 10-spline pinion (which is generally considered for earlier). All I'm suggesting is, hard to tell what you really have, without looking inside. And, even then, you probably won't be able to pin down an exact year. And, after you learn all of this, then, for what purpose?
Go with the basics... 35-36 has spring hangers on the radius rods. 37-40 has spring hangers forged on axle housing ends. No zirk fitting on TT means 35 up to somewhere around 37-38. A zirk fitting on the TT means somewhere around 37-38, up to end of that style (40). Some might say 41, but 41 introduces another can of worms (unique spring hangers). Clear as mud? JMHO
bobH is offline   Reply With Quote
