Old 10-07-2020, 06:28 PM   #1
russcc
Default 59L startup oil pressure at crank speed.
Followed the suggestion of one of the Fordbarner, pouring oil down through output side of the full flow oil system, and removing the plugs. Got oil pressure on cranking right off. Mechanical oil pressure gauge.
This engine is going in the '40 and is 6 volt. Is 20#s oil pressure cranking a 6 volt system satisfactory ?
Old 10-07-2020, 06:37 PM   #2
Zeke3
Zeke3's Avatar
Default Re: 59L startup oil pressure at crank speed.
Cranking speed is probably around 200 rpm at the most. I think 20 psi is a good oil pressure for cranking the engine.
Zeke3 is offline   Reply With Quote
Old 10-07-2020, 09:39 PM   #3
cadillac512
cadillac512's Avatar
Yes, that's good.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 10-07-2020, 09:48 PM   #4
tubman
tubman's Avatar
I would be happy with anything on the gauge at cranking speed.
Old 10-08-2020, 05:40 AM   #5
russcc
Thank you all for sharing your experience.
Old 10-08-2020, 05:52 AM   #6
Ol' Ron
Ol' Ron's Avatar
Sounds alittle high, what grade of oil are you using??
Old 10-08-2020, 06:09 PM   #7
russcc
Good point Ron. Shell Rotella 15W-40. Would a lighter oil be better idea, especially since the weather has turned cooler hear in MA. I do plan to put the engine in a heated area before startup.
Old 10-08-2020, 10:27 PM   #8
flatjack9
flatjack9's Avatar
I don't see any problem. I generally get more pressure, but I'm cranking with 12 volts.As Tubman says, if you are getting pressure, be happy and run it.
Old 10-09-2020, 07:49 AM   #9
Ol' Ron
Ol' Ron's Avatar
I don't see any problem either. However the heaver oil restricts flow, especially with stock bearing clearance. It seems that everybody wants to see hi numbers on the gauge, but flow through the bearing is more important.
Old 10-09-2020, 05:34 PM   #10
russcc
flow through the bearings. Good point Ron. I may swap the 15W-40 for a lower viscosity.
Old 10-09-2020, 08:21 PM   #11
flatjack9
flatjack9's Avatar
I run 10W- 30 and my engine is 25 years old.
Old 10-09-2020, 11:19 PM   #12
Ol' Ron
Ol' Ron's Avatar
Yes, for stock bearings,10/30 in a quality oil does a great job, AS you open your clearances a higher viscosity canbe used, their are sme very good racing oils out there.y
