Old 09-18-2020, 10:43 AM   #21
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: Cornhead grease and steering gear oil.
I did an experiment several years ago by mixing JDCH grease and the gear oil I normally use in the transmission and rear of my '35 fordor. It did initially mix well, and this mix did not separate during the time I kept it in a small jar on my work bench, probably a couple months. I did this experiment when I started using JDCHG in my steering box because I knew I could not drain all the existing oil out of the box.
John
Old 09-19-2020, 06:39 AM   #22
38coop
Thanks for your reply JM. I will get what i can out of the steering box and not worry about the rest.
38coop is offline   Reply With Quote
Old 11-08-2020, 11:31 PM   #23
cajunfirehawk
cajunfirehawk's Avatar
Thumbs up Re: Cornhead grease and steering gear oil.
Just did my 36 to 37 & up gear box swap and filled my rebuilt box w/cornhead, assume this is good?
Regards,
Todd
1936 FORD Tudor Slantback
"cajunhotrodder" on instagram/youtube
cajunfirehawk is offline   Reply With Quote
Old 11-08-2020, 11:41 PM   #24
Rudolph
Rudolph's Avatar
I put semi fluid grease in my steering box and it was like having power steering, way better than oil, also my headers wrap around both sides of the steering box for max heat.
Rudolph is offline   Reply With Quote
