Old 09-03-2020, 07:45 PM   #1
my4dv8
Default Y block big truck water pump/ fan.
We wish to raise the fan height on a Y block in a model A Ford . I have in my parts piling system a big truck Y block water pump with the ears on top for the fan . But we are unsure what the fan assembly looks like. Tried a flathead one but the assembly is too long and it has the wide pulley. I presume we need a double sheave crank pulley also?
Any help appreciated.
my4dv8 is offline   Reply With Quote
Old 09-03-2020, 07:55 PM   #2
Gene F
Gene F's Avatar
Default Re: Y block big truck water pump/ fan.
That is an option. I would opt for a plastic fan shroud that you cut when it comes. Meaning no hole for the fan.
Old 09-03-2020, 08:47 PM   #3
dmsfrr
dmsfrr's Avatar
Originally Posted by my4dv8 View Post
We wish to raise the fan height on a Y block in a model A Ford . I have in my parts piling system a big truck Y block water pump with the ears on top for the fan . But we are unsure what the fan assembly looks like. ... I presume we need a double sheave crank pulley also?
Wish I had another or a better photo of this (blue) one for you but I don't. It's just a random photo I copied.
I'm assuming the 2 empty bolt holes on the top surface of the (red) timing cover are to mount the fan bracket. ???
Old 09-03-2020, 10:13 PM   #4
my4dv8
Thanks @dmsfrr , thats a head start . Fan pulley sticks out further than i expected . Hopefully someone has a head on view.
Old 09-12-2020, 03:59 PM   #5
my4dv8
So a random pic i found showing what I believe are the parts required . We do not have a fan or hub.
File Type: jpeg 53DB5AA6-2DD6-407C-A01D-A2A50BC59E53.jpeg (353.2 KB, 7 views)
