Old 07-25-2020, 11:29 AM   #1
DMMuir
Default Rear brakes ‘40
Rear brakes were rubbing. Anyone see a known issue? Just this side, and they look like they were assembled right
DMMuir is offline   Reply With Quote
Old 07-25-2020, 01:34 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Rear brakes ‘40
I see your later post above! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-25-2020, 01:40 PM   #3
Mart
Mart's Avatar
Dave, did you adjust the lower eccentric pivots?
Old 07-25-2020, 01:52 PM   #4
philipswanson
I had the same problem on both sides in the rear. Went with the Lincolns up front. Adjusted the rears for lightest drag and ignored other methods. Maybe later I will do Lincolns on the back too but they are high $$$. In the meantime they seam to be doing ok but I sure don't like them.
philipswanson is offline   Reply With Quote
