Old 05-29-2017, 06:32 AM   #41
inex01
inex01's Avatar
Default Re: Garage Find
Originally Posted by Tom Wesenberg View Post
A clutch disc with springs can chatter just as well as a plain one.
For chatter, I'd look at flywheel housing alignment, oil on the disc, clutch pressure plate problems, and loose or worn parts along the driveline.
Hi Tom, I do not have a "Chatter" problem was just making a talking point
Chuck McDonald,
Member of AACA, Model A Club, NRA
inex01 is offline   Reply With Quote
Old 05-29-2017, 06:34 AM   #42
inex01
inex01's Avatar
Hi Tom, was just curious
Chuck McDonald,
Last edited by inex01; 05-29-2017 at 06:58 AM. Reason: Wanted to delete but could not figure out how
Old 05-30-2017, 04:14 PM   #43
inex01
inex01's Avatar
Today my Friend and I pulled the valves, cam & lifters then replaced the timing gears, lifters with the double nut adjustable, brought the seats back to the correct angle and then lapped in all the valves, tomorrow we will install and adjust the valves. Here are some pictures
Chuck McDonald,
Old 06-06-2017, 03:07 AM   #44
inex01
inex01's Avatar
Tore the engine down checked all babbits and all have shims and plenty of life, actually like "NEW", I installed adjustable lifters, springs, and valves. and ran on the test stand. Here is the link.
https://www.youtube.com/playlist?lis...XfzHSW3jhvGZ01
I now have two complete running engines, and I mean complete right down to the generator and may consider selling one so if anyone needs one let me know
Chuck McDonald,
Old 06-06-2017, 03:42 AM   #45
THAIGUY
Send a message via MSN to THAIGUY
Aloha chuck
really sounds and runs well..you probably found an old one that was maintained instead of being run into the ground like most of these were before the war was over. Hope you find a buyer..i'm sure you will.
Don
THAIGUY is offline   Reply With Quote
Old 06-06-2017, 04:11 AM   #46
inex01
inex01's Avatar
Originally Posted by THAIGUY View Post
Aloha chuck
Don
Hi Don, Not really trying to sell engine, but I now have two complete running engines and if someone really needs one and makes a fair offer I will let one go, I am what you would call a "Horder" but willing to help out a fellow Model A'er
Chuck McDonald,
Old 06-06-2017, 10:32 AM   #47
JDupuis
JDupuis's Avatar
Good video Chuck. Sounds great! Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
