10-16-2022, 04:15 PM | #1 |
Use of Chevy valves/seats in A engine
I have a 30 Coupe which had an engine rebuild by another owner in 2006. The list of things done says Chevy valves/seats were installed. In another post about valves, Brent replied that he had used 1980 Chevy Chevette (Corvette?) seats before in a B motor.. Does anyone know if this has been the common Chevy seats that are used in the model A? I have been unable to track what year/model Chevy valve seats are in my car.
10-17-2022, 02:12 PM | #2 |
Re: Use of Chevy valves/seats in A engine
VALVE SET MODERN
Part # A-6505-M Model Year 28-34 Modern stainless steel valve with a straight stem, and a -pc style guide. Valves have a tuffrided finish for improved oil retention and reduced friction. Kit comes with 8 valves, 8 guides, 8 retainers, and 16 keepers. Kit is a direct replacement that requires no modifications. 1.537" head diameter. $147.00 SET Hello this is what your engine may have, this is from Snyders . |
10-18-2022, 05:29 AM | #3 |
The engine should be fed a couple good doses of anti-rejection meds though.
10-18-2022, 07:06 AM | #4 |
Henry must be grumbling!! Sacrilege
10-18-2022, 07:30 AM | #5 |
The Chevette was the replacement for the Vega so it had two small engines used during its run. Isuzu made a lot of those engines. They were 1.4 and 1.6 litre ohv engines and likely did have a thin seat by comparison to others of the same diameter. The B engine has thinner areas in its top end part of the casting that come closer to water than the model A. I'm sure Brent did the research to find a seat that was safer to use on the B engine. It may not be as critical on the model A but it wouldn't hurt to be conservative when counter boring the block. The seats used on the OPs engine were likely a common replacement seat for model A unless the valves are larger in diameter than original.
10-18-2022, 08:35 AM | #6 | ||
http://www.sbi-e-catalog.com/PartDetail.aspx?PartNumber=SB1625-1&PartType=Valve%20Seats As far as discerning what seat is used in your engine, I think it would be very difficult to know exactly without removing it where you can measure the counterbore and the diameter of the ID and OD of the seat itself. Also realize that these seats can be ordered in different depths and oversizes to fit needs (-i.e.,: loose seat in counterbore, etc.). Quote:
10-18-2022, 08:42 AM | #7 |
If you knew the overall length, head diameter, and stem diameter, it would help narrow down what you have. I'm not clear if the engine is apart or not. Small block Chevy exhaust valves are a drop in for the Flathead V8, never compared them to an A valve.
10-18-2022, 09:05 AM | #8 |
as far as seats go, as Brett mentioned, SBI is a great resource.
I have found that if replacing seats with something close, I have had custom seats made by Tucker Valve seats. But, as I re-read the OP, I don't see any mention of a problem. J
As Carroll Smith wrote; All Failures are Human in Origin. |
10-19-2022, 07:00 PM | #9 |
Thanks to all for the info. The engine is not apart and I don't have an identified problem other than 6% lower compression in #2. I am just trying to figure out what I might have. Henry may be rollin' but I'm not! The shop that put them in thought something was being improved.
