01-26-2024, 05:58 PM | #1 |
91A Rod
Well, this is a first for me. Been fiddling with flatheads for 40 years now. Checking a set of 91A rods with my Sunnen A300 gauge. Snugged the rod nuts down with a 3/8 ratchet then torque them to 45 with torque wrench. The nut barely got snug and the rod bolt let go. Never had this happen before.
01-26-2024, 06:12 PM | #2 |
Re: 91A Rod
Ouch-yeah. You know it did that so you'll worry about the rest of 'em.
01-26-2024, 06:19 PM | #3 |
Re: 91A Rod
01-27-2024, 08:26 AM | #4 |
Re: 91A Rod
Was it new?
01-27-2024, 08:58 AM | #5 |
Re: 91A Rod
01-27-2024, 10:03 AM | #6 |
Re: 91A Rod
01-27-2024, 10:48 AM | #7 |
Re: 91A Rod
01-27-2024, 11:04 AM | #8 |
Re: 91A Rod
That is one of the reasons I use the aftermarket rods. Who knows how much those integral "bolts" have been stretched by over torquing. How many guys back in the day even had a torque wrench? It is amazing how well the stock rods have held up all these years. Maybe the rod that broke had a flaw from day 1 and finally let go.
I am glad you found it when you did! |
01-27-2024, 01:27 PM | #9 | |
Re: 91A Rod
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
01-27-2024, 01:51 PM | #10 |
Re: 91A Rod
Many use cap screws.
01-28-2024, 11:52 AM | #11 | |
Re: 91A Rod
01-28-2024, 12:08 PM | #12 |
Re: 91A Rod
WOW!! I have a set balanced in a crank assembly for my last build?? Now what??
Gramps |
01-28-2024, 12:28 PM | #13 | |
Re: 91A Rod
My favorite rod for a nice hot rod engine. Not a race engine rod. |
01-28-2024, 01:21 PM | #14 |
Re: 91A Rod
Tim, The 3 sets of Scat rods I am running all had socket head cap screws. I would think they have pictures of them online somewhere.
Mike |
01-28-2024, 02:41 PM | #15 |
Re: 91A Rod
The aftermarket H-beam rods all use modern cap-screws. Also, there are different quality of cap-screws, so you can even go up to higher strength ones if that makes you happy. Truth be told, at our measly horsepower levels (unblown street engines), there is no head to upgrade the cap screws.
01-28-2024, 05:32 PM | #16 |
Re: 91A Rod
NOS stock rods will perform exceedingly well even in 100% nitro burning engines if a few simple things are done to them.
First, magnaflux the rods. Then shot peen them. Have the caps torqued to spec when shotpeening. Be sure to use shot that is half the diameter of the smallest radius. You will have to determine that number as I haven't done a set in 30 years. After shot peening and reconditioning the big end, install new pin bushings and align bore them to the big end. DO NOT use a rod alignment press on the rods after they have been shot peened. |
