12-20-2023, 05:34 PM | #1 |
21A vs 91A rods
I’ve always read that the 21A rods were the preferred choice when using a stroker crankshaft. What makes it superior to the 91A rod ? I just weighed some of each on my digital scales. The 21A weighs 462 vs 464 for the 91A. Other than that I can’t see any physical differences in the two.
12-20-2023, 08:26 PM | #2 | |
Re: 21A vs 91A rods
12-20-2023, 08:46 PM | #3 |
Re: 21A vs 91A rods
I’m building a new engine using a C69 block with 4 1/8 stroke crankshaft with 3 3/8 bore. I have a really nice set of 91A rods that have been resized and rebushed on the small end and I have enough 21A rods but they need resizing and rebushed. I have the machine to perform this but was wondering if it’s really worth it.
12-20-2023, 08:55 PM | #4 | |
Re: 21A vs 91A rods
I would magnaflux them first before anything, even if they are new. Check alignment after all machine work is done or bore the bushing with the rod mounted on a big end fixture. The advantage to this is all rods end up the same length. Use Marsden grade 8 nuts. Last edited by Pete; 12-20-2023 at 09:03 PM. |
12-20-2023, 09:19 PM | #5 |
Re: 21A vs 91A rods
Not a race engine. Street engine only.
12-20-2023, 09:21 PM | #6 |
Re: 21A vs 91A rods
12-20-2023, 09:23 PM | #7 |
Re: 21A vs 91A rods
12-20-2023, 09:26 PM | #8 |
Re: 21A vs 91A rods
12-20-2023, 09:36 PM | #9 |
Re: 21A vs 91A rods
12-20-2023, 09:47 PM | #10 |
Re: 21A vs 91A rods
12-20-2023, 10:32 PM | #11 |
Re: 21A vs 91A rods
12-20-2023, 10:37 PM | #12 |
Re: 21A vs 91A rods
12-20-2023, 11:26 PM | #13 |
Re: 21A vs 91A rods
There is probably a difference between these rods, but nobody seems to know what it is. The 21a were never used in production engines, I was told/
12-21-2023, 06:13 PM | #14 |
Re: 21A vs 91A rods
What’s the difference of a 99 rod?
12-21-2023, 06:17 PM | #15 |
Re: 21A vs 91A rods
12-21-2023, 06:18 PM | #16 |
Re: 21A vs 91A rods
Same as a 29A rod?
12-21-2023, 06:51 PM | #17 |
Re: 21A vs 91A rods
