Old 09-01-2021, 11:05 AM   #1
kketchmark
kketchmark's Avatar
Default 49 F1 Locking Pin Nut - For Spindle Bolt (King Pin)
I got my kings pins replaced but the new Spindle lock Bolt just has a normal nut. Would like to find a replacement Nut that has the closed end/Steering stop. Something like this that MAC sales.
https://www.macsautoparts.com/lockin...ails_tab-title
Not sure if that is correct or not. Another note the new king pin kit didn't include the plug on bottom. Should I fill the end with silicon or just let it be open?
49 F-1 8BA
kketchmark is offline   Reply With Quote
Old 09-01-2021, 03:42 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 49 F1 Locking Pin Nut - For Spindle Bolt (King Pin)
What is wrong with the ones that Mac's sells
You could cobber something up using threaded rod coupling nuts with the correct thread but the end would not be sealed.
Old 09-01-2021, 03:45 PM   #3
kketchmark
kketchmark's Avatar
I am not sure they are correct. I guess I would have to email/call them and ask what the thread is.
49 F-1 8BA
Old 09-01-2021, 05:34 PM   #4
Brian
Brian's Avatar
Can't you re-use the original nuts?
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 09-02-2021, 06:04 PM   #5
kketchmark
kketchmark's Avatar
The guy that replaced the king pings tossed the old set in the trash. But i did find a set digging for some other parts. Go figure.
49 F-1 8BA
Old 09-02-2021, 11:57 PM   #6
JSeery
JSeery's Avatar
Finding original used parts is often better than new!
