06-07-2021, 07:19 PM | #1 |
Quick Rope Seal Question
Hi Guys:
I have a new left over 59a lower front oil pan rope seal that came with a pan gasket set- Will this work on my 8ba oil pan?? Also, no trim on the front, top and bottom, correct?? Thanks All, Dave |
06-08-2021, 12:21 AM | #2 |
Re: Quick Rope Seal Question
The "no trim" instruction would apply, but not to the absurd. I got a rope that had to be trimmed by more than an inch. Can't tell you about an 8BA, that modern stuff is all Greek to me.
Alan |
06-08-2021, 10:04 AM | #3 | |
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
06-08-2021, 11:07 AM | #4 |
