Old 09-13-2019, 09:58 PM   #1
BadgerA
BadgerA's Avatar
Default Model A Truck Running Board Question
I have what I believe is a set of original 30/31 pick up running boards. I recently compared them against a set of new Rootliebs that a friend purchased for his truck. His new boards appear very similar to mine on the top and side. However, the mounting brackets on the bottom are quite different. Difference in the ends of the brackets and difference in the cut outs for mounting. Can someone confirm which is correct? Perhaps the pictures will make this question clearer. Thanks.
BadgerA is offline   Reply With Quote
Old 09-14-2019, 08:47 AM   #2
BadgerA
BadgerA's Avatar
Default Re: Model A Truck Running Board Question
Anyone?
Old 09-14-2019, 10:07 AM   #3
Neil Wilson
Neil Wilson's Avatar
The original would be as Ford produced it as far as I know.
[email protected] - email contact
https://aafords.com Ford Model AA Truck Club @ aafords.com
Neil Wilson is offline   Reply With Quote
Old 09-14-2019, 10:17 AM   #4
BadgerA
BadgerA's Avatar
Thanks for the reply Neal. My specific question is whether the new Rootlieb board as pictured has incorrect brackets. I.E., I want to confirm that the other board pictured is indeed an original. And, if the new Rootlieb board has incorrect brackets, why did they produce them that way? I would think it would be just as easy to make the brackets the correct way with less work for stamping, etc.
Does anyone out there have original boards? If so, how are the brackets made? Are they the same as what I believe to me my original board as pictured?
Old 09-14-2019, 12:09 PM   #5
Joe K
Joe K's Avatar
For my 29CC pickup I have original board and a set of Rootliebs scheduled for replacement. I have noticed a similar difference in the mount, but the boards are not in front of me at this moment to confirm an answer to your query.
If you don't get an answer before Sunday pm when I return home, I'll take a look.
I think the difference is not detectable when the bracket covers the applied clip - but I'll comment later on that.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 09-14-2019, 04:32 PM   #6
Tudortomnz
Tudortomnz's Avatar
The original brackets & boards are ones on the right. Do they have Made in USA stamped topside? Canadian ones are stamped as such. Cheers
Tudortomnz is offline   Reply With Quote
Old 09-14-2019, 10:46 PM   #7
BadgerA
BadgerA's Avatar
No visible Made In USA stamp on the topside on my boards.
