Old 11-03-2018, 04:05 PM   #1
Daveyjonez
Default 33-34 and 35-36 coupe trunk hinges
Hi Guys:
If anyone would know, I figured it would be here:
What are the differences between the two hinge assemblies, and can the 35-36 be adapted to a 34?
The 34 hinges are very difficult to find right now, I figured if the 36 stuff would work it would widen my options.
Thanks in advance guys,
Dave
Daveyjonez is offline   Reply With Quote
Old 11-03-2018, 07:47 PM   #2
JSeery
JSeery's Avatar
Default Re: 33-34 and 35-36 coupe trunk hinges
I have no idea, but would be interested in the answer.
Old 11-03-2018, 09:16 PM   #3
petehoovie
petehoovie's Avatar
Oops! Thought you were talking about a sedan....
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 11-04-2018, 06:12 PM   #4
Barn Junk
Barn Junk's Avatar
I've just been going thru this, myself. From what I have found, the cast pivot blocks that mount on the body are the same between 33-34 and 35-36 coupe hinges But the "U" sharped cast pivot arms that fasten to the lids are a little different. The 33-34 pivot arms seem to be a little shorter between the lid mounting flange and the pivot point.
I do now have an extra set of 33-34 trunk hinges that I would consider doing some trading for the correct 35-36 trunk type. The 33-34 pivot arms usually have a readable visible "40" part number cast in them and The 35-36 type have a "48" number.
Barn Junk is offline   Reply With Quote
Old 11-04-2018, 08:57 PM   #5
Karl Wescott
Karl Wescott's Avatar
Barn Find got most of the differences, the other main one is the holes for mounting to the deck lid on 1933-34 are sized for #12-24, and 1935-36 is 5/16-24.
There is a very good chance that repro hinges will be readily available early next year for the 1933-34, a bit later for 1935-36.
Karl Wescott is offline   Reply With Quote
