Old 09-29-2015, 07:52 AM   #1
36 ford
36 ford's Avatar
Default 1939 Deluxe mystery wire
Out of the cowl harness is a yellow/black wire with a closed end that attaches somewhere. It is a "'hot wire" See pics..
Images of the generator and solenoid wiring may be helpful as you ponder.
Thanks!
Phil
36 ford is offline   Reply With Quote
Old 09-29-2015, 08:28 AM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: 1939 Deluxe mystery wire
Isnt there a cable missing on the oilpressure sender in the pic...
Old 09-29-2015, 09:58 AM   #3
cmbrucew
cmbrucew's Avatar
36
Could that wire be BG, if so it will power the oil. temp and fuel gauges. It would be coming from the IGN switch.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 09-29-2015, 11:51 AM   #4
supereal
supereal's Avatar
The wiring diagram shows a yellow black wire leading from the junction of the black wire from that connects the battery to the charging circuit, with the other end feeding the ignition switch.That junction also connects to a large yellow wire that leads to the ammeter.
supereal is offline   Reply With Quote
Old 09-29-2015, 12:04 PM   #5
flatheadmurre
You can see them at the starter solenoide.
Old 09-29-2015, 12:06 PM   #6
flatheadmurre
Is it permanent live or ignition switched ?
I dont se a horn setup might be for that...
Old 09-29-2015, 12:08 PM   #7
petehoovie
petehoovie's Avatar
I agree Mr. Murre.....Looks like the horn wire to me.....
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 09-29-2015, 01:26 PM   #8
Vic Piano
Vic Piano's Avatar
My '39 CS is a DeLuxe, with the voltage regulator, it has a yellow/Black wire coming from the harness and going to the Armature post on the voltage regulator however, the OEM style harness I installed, looks different from the one in your photos.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 09-29-2015, 08:36 PM   #9
Lawson Cox
Lawson Cox's Avatar
Does your oil pressure gauge work with that wire disconnected? I think the wire goes to oil pressure switch.
Old 09-30-2015, 07:06 AM   #10
jimTN
I think Vic has it. That wire looks like the VR wire because it is thicker than a sending unit wire.
jimTN is offline   Reply With Quote
Old 09-30-2015, 07:29 AM   #11
Cecil/WV
Cecil/WV's Avatar
Wires to the gauges would not be hot.
Cecil/WV is offline   Reply With Quote
Old 09-30-2015, 07:33 AM   #12
HCO41
I thought the oil pressure sending unit provided a variable ground to the gauge. Seems that hooking a "hot" wire to the sender would be a direct short. JMHO
Howard
HCO41 is offline   Reply With Quote
Old 09-30-2015, 08:33 AM   #13
flatheadmurre
The wire to the sender is live if tested with a voltmeter.
If its a KS its pretty close to batteryvoltage to.
Old 09-30-2015, 09:16 AM   #14
51 MERC-CT
51 MERC-CT's Avatar
'39 schematic shows BY wire from sender to panel gage which is fed by switched BG wire.
Looks like it goes to oil sender which is obviously devoid of a wire in your picture.
Old 09-30-2015, 09:44 AM   #15
deuce_roadster
deuce_roadster's Avatar
Show a picture of the voltage regulator. Does it have all the proper wires? That loose wire is large and for heavy current. I think it either should go to the vr or it belongs under the dash and someone pulled it through the firewall.
Old 09-30-2015, 09:53 AM   #16
3340
3340's Avatar
I Agree With Deuce _ Roadster
3340 is offline   Reply With Quote
Old 09-30-2015, 10:38 AM   #17
40cpe
40cpe's Avatar
The ground end (sender terminal) of a gauge will show voltage unless grounded. Does the wire in question show voltage only with the ignition on, or all the time?
40cpe is offline   Reply With Quote
Old 09-30-2015, 10:46 AM   #18
flatheadmurre
A little feedback from the source should be nice....
Old 09-30-2015, 10:57 AM   #19
51 MERC-CT
51 MERC-CT's Avatar
Seems to be some confusion as to the size of the wire.
Mainly because the terminal end is closer to the camera giving that illusion.
Make a comparison to where the wire is closest to the sending unit.
Old 09-30-2015, 03:17 PM   #20
bbrust
bbrust's Avatar
We believe the wire does goes to the oil pressure sender. It only has current with the ignition on. The schematic in post 14 shows a BY color wire but the wire in Phil's harness appears to be more YB which may have led to our confusion. The Voltage Regulator has the correct wires and the car did start prior to installation of a crab distributor. We are working on new plug wires as time permits and haven't been able to verify that the oil pressure gauge works. Thanks to everyone that has responded and Phil will provide an update once the plug wires are installed and the resistance checked. We live in separate towns and don't get to work on Phil's car as much as possible. Bob
bbrust is offline   Reply With Quote
