06-02-2015, 06:52 PM | #1 |
Rotor Play
Just noticed (while correcting another problem) the rotor on my '30 coupe has what looks like about a quarter-inch of play. That is, it doesn't set tight on the cam. Tried a new rotor and it's the same. Is this a normal fit? Car seems to run okay but it made me wonder.
06-02-2015, 07:05 PM | #2 |
Re: Rotor Play
What you may feeling is the backlash in the dist dr shaft. When you move the rotor is the cam it sets into moving??
Paul in CT |
06-02-2015, 07:52 PM | #3 |
Re: Rotor Play
Is this side to side play or is it rotational ?
1/4" bushing play is a lot. 1/4" rotational is not. I have a feeling the rotational play is in the shaft and not the rotor/cam. When setting the timing that play needs to be taken into account. |
06-02-2015, 09:29 PM | #4 |
Re: Rotor Play
Check out the 2nd and 3rd diagrams for an explanation of side-to-side vs rotational play. I think this might help explain the other comments. Hope so!
http://modelabasics.com/Ignition.htm |
06-02-2015, 09:53 PM | #5 |
Re: Rotor Play
I had a rotor that was wobbly on the cam. It wasn't old looking and I can't remember which supplier I bought it from. I bought a replacement from Brattons and it fit very snugly. I also replaced the one piece shaft with a two piece drilled in the top for lubrication. It eliminated most of the backlash that I had.
06-03-2015, 07:59 AM | #6 |
Re: Rotor Play
06-03-2015, 12:32 PM | #7 |
Re: Rotor Play
The distributor cam screw head may be too high.
Bob |
06-03-2015, 06:01 PM | #8 |
Re: Rotor Play
Seems like a case of the cam slot being too wide for the nib on the rotor that fits into it. Or vice versa.
06-04-2015, 10:11 AM | #9 |
Re: Rotor Play
Got any other cams to check the slot? The first time I read this I thought the cam nut was possibly sticking up to high so the rotor could not seat properly.
Bob |
06-04-2015, 12:13 PM | #10 | |
Re: Rotor Play
