Old 02-29-2024, 06:53 AM   #1
khnaess
Default Petcock
Hello.
When I drain the coolant of my 1937 v8-60, i just pull one of the lower radiator hoses. I have 2 petcocks on the engine block but they seems to be stucked and I have not dared to use force on them. As the picture shows, they have not been used for years. Is there a trick to free them? I guess I am just supposed to turn the paddle on the top, not the nut on the bottom?
khnaess is offline   Reply With Quote
Old 02-29-2024, 07:01 AM   #2
deuce lover
deuce lover's Avatar
Default Re: Petcock
Yes the paddle on top
Old 02-29-2024, 08:36 AM   #3
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Petcock
sometimes they have to be taken apart,cleaned and lubricated with cock grease, a tube of it is $$ but enough to last a lifetime, Langs model T parts sells it.
Old 02-29-2024, 08:38 AM   #4
kurt v
Default Re: Petcock
i would bet that they are plugged up with rust and mud, might be more than you want to get into when you get started.
kurt
kurt v is offline   Reply With Quote
Old 02-29-2024, 09:23 AM   #5
Jack E/NJ
Jack E/NJ's Avatar
Default Re: Petcock
Might be better to simply replace with brass pipe plugs. Easier to get plugs in and out with wrench than turn a handle in that location.
Old 02-29-2024, 10:49 AM   #6
19Fordy
19Fordy's Avatar
Default Re: Petcock
Can you fit the tip of a propane torch in that space between the header and heat up the body of the petcock so you can unscrew it? Let it heat up and cool down several times. Apply penetrating oil. Be gentle.
By spraying a premium quality penetrating oil on your stuck bolt, you can reduce the amount of torque you need to apply by as much as 50%.
Old 02-29-2024, 10:52 AM   #7
Terry,OH
Terry,OH's Avatar
Default Re: Petcock
That is the 48- style pet cock first offered in 35. I too would not use it for many of the reasons above.
Old 02-29-2024, 11:16 AM   #8
alanwoodieman
Default Re: Petcock
be careful trying to remove the petcocks, I have seen more than one that broke off and also have seen cracked blocks from trying to remove them
Old 02-29-2024, 11:51 AM   #9
khnaess
Default Re: Petcock
Thank you for all your response and tips, you are the best😊 I guess I just leave them alone , and just unhook the radiator hose . I am having trouble getting my newly overhauled water pump tight so I guess I have to drain it again🥲🥲 The v860 pumps are tricky…
Old 02-29-2024, 01:38 PM   #10
19Fordy
19Fordy's Avatar
Default Re: Petcock
Be veryful careful not to strip the threads re: water pump installation. Don't overtighten.
Old 02-29-2024, 02:07 PM   #11
Graeme / New Zealand
Graeme / New Zealand's Avatar
Default Re: Petcock
The mind boggles
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 02-29-2024, 05:39 PM   #12
tubman
tubman's Avatar
Default Re: Petcock
Originally Posted by Graeme / New Zealand View Post
The mind boggles
GB
I was wondering when someone would catch this.
We are getting old.
