01-05-2024, 03:19 PM | #1 |
38 ford motor change
I have a 1938 coupe with a 60hp engine can anyone know what changes I have to make to install a 100hp i have been told the front crossmember has to be change?
01-05-2024, 03:41 PM | #2 |
Re: 38 ford motor change
I don’t believe you have to change crossmember. They are 60 only and kinda an add on. The big v8 engine mount and hose should already be there. A big v8 transmission with 38 style rear trans housing mount. Radiator. 60 is smaller. Should be the main items with some other odds and ends.
01-05-2024, 03:49 PM | #3 |
Kiwi pretty much nailed it.
There are brackets riveted to the cross member for the 60HP that will have to be removed. Easy task. Radiator and side shrouds are different.
01-05-2024, 03:50 PM | #4 |
Probably want to change the rear axle gears also as I think the 60hp
had 4.44 gears. |
01-05-2024, 03:59 PM | #5 |
It's a pretty easy swap as other have given tips about. Albiet, time consuming. It will be worth the work.
Bob C mentioned the rear end rear ratio. I would definately consider 3.54 gearing. |
01-05-2024, 04:49 PM | #6 | |
BELOW are the two "ADAPTER" mounts that you will have to remove from the front crossmember. This pic BELOW shows what these little mounts look like installed and supporting the anemic little engine. And here they are on their way to becoming "spare parts"! Coop . |
01-11-2024, 03:24 PM | #7 |
Is the trans the same?
01-11-2024, 03:25 PM | #8 |
no,totally different, rear has different ratio usually 4:44
the wheels can be more narrow also, and the front spring is weaker because of less engine weight, |
01-11-2024, 03:56 PM | #9 |
What trans should I be looking for?
01-11-2024, 04:27 PM | #10 |
78-7006? case, which is 1937 and up until the 40 style sideload case. where are you located?
01-11-2024, 05:45 PM | #11 |
The 78 case was used in cars through 1939 but that was the change over year for the new synchronizer. 1937 & 38 transmissions work OK but have the early synchronizer. Pickups kept the case till replaced in 1952 but the pickup version has the short main shaft set up starting in 1942 for open drive and the gearing is more truck like in some cases. Side loaders used up through 1948 have good guts in them and they will work in the 78 case. The double detent shifter and a 91A 2nd/high shift fork works with the late synchro and are the best parts to look for if you can find them. The rear engine mount may be the same on the 60HP but I'm not sure enough to say without looking up the parts in the green bible. Mac VP's book is a must if piece parting a transmission together. Good complete transmissions are getting harder to source every year. Hot rodders used to be the best source since they usually pitch the old 3-speed. Everybody wants a 5-speed now days.
01-19-2024, 03:32 PM | #12 |
Orange County Cal.
01-19-2024, 03:34 PM | #13 |
How can you use a 5 speed with close drive shaft?
01-19-2024, 03:58 PM | #14 |
I think you misunderstood. I believe Rotorwrench was just saying that 3 speed boxes are more available today because hotrodders take them out to go brand x.
Alan |
01-19-2024, 04:35 PM | #15 |
If you're REALLY serious, it CAN be done similar to how we did it as shown in this lengthy thread along with all the "hows, whys and many, many pictures". Click the link BELOW! Coop https://www.fordbarn.com/forum/showt...T5+TORQUE+TUBE Last edited by V8COOPMAN; 01-19-2024 at 04:46 PM. |
01-19-2024, 05:02 PM | #16 |
Thank You ,but I'm not up to that change for the 5 speed
01-19-2024, 06:47 PM | #17 |
what’s wrong with your 60, they do require a different driving technique, no good at lugging, wind second out to 45, downshift to 2nd as soon as it slows to 40.
when I had one it was happy at 65, flat out 73 as advertised, kept below 60 should give over 20 mpg, about 18 at 70, 25 mpg cruising at 50. at first I was afraid to drive like that until I bought a lot of engine parts from old hydroplane racer, he told me that a stock bottom end was good for more than 2 seasons at 7000 rpm, but 1/2 season at 7500. |
01-20-2024, 08:33 AM | #18 |
We have a local V8 Club member with a 60 hp 1937 pickup and he drives it on most of our tours. He reports it is more sensitive to tuning than the bigger engines since the loss in power is much more noticeable. In good tune it goes well. He added the lower ratio overdrive from Mitchell and kept the stock 60 hp axle ratio. He recently added dual exhaust and it sounds good.
