Old 08-11-2012, 08:04 PM   #1
jmeckel
jmeckel's Avatar
Default Zenith Carb Question
I am looking for some information about Zenith 1 carbs. I know Zenith 2 carbs are single venturi. Were all Zenith 1 carbs dual venturi? If not how do you tell which ones were other than if they have a dual venturi in them?
Thanks for any help
Jon
"If you choose to not decide, you still have made a choice!" RUSH
Don't tell me what you know..... Tell me what you have done.
jmeckel is offline   Reply With Quote
Old 08-11-2012, 08:12 PM   #2
Jim Mason
Jim Mason's Avatar
Default Re: Zenith Carb Question
I have some carb information on my site. Also check Vince's (free) site at www.fordgarage.com for the numbering information
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
Old 08-11-2012, 08:16 PM   #3
TinCup
TinCup's Avatar
Only the early Zenith carbs were double Venturi. Go to Vince Falters site for a great overview. Www.fordgarage.com
TinCup is offline   Reply With Quote
Old 08-11-2012, 08:18 PM   #4
kenparker
kenparker's Avatar
The Zenith ! means it was made by the Zenith Corporation. Zenith 2 means it was made by Holley company. Zenith 1 or Zenith 2 has nothing to do with whether it is a single or dual Venturi. Zenith did make a Double Venturi - esentially it is a Venturi inside a Venturi - But it only had Zenith on the side and a "Z" on the upper half - no 1 . Holley also made a double Venturi and it is marked with an "H" on the upper and lower halves. The double Venturi's were made in 1927 and early 1928.
kenparker is offline   Reply With Quote
Old 08-11-2012, 08:26 PM   #5
jmeckel
jmeckel's Avatar
Just the info I was looking for.
Thank you all very much.
Jon
Old 08-11-2012, 11:17 PM   #6
Ron in Quincy
Ron in Quincy's Avatar
The change occured in January 1929; Zenith-1 was assigned to the Zenith Company, Zenith-2 was assigned to the Holley Company; when Ford cam out with their Carburetor in January 1931 Zenith-3 was assigned to the Ford Motor Company.
The very early Zenith was a Double Venturi; the bowl was only marked Zenith and the upper housing had a Z on the back side; on the lower housing there was a boss on the back side with a pin which secured the double venturi; on the next lower housing the boss with retaining pin was moved to the front of the housing but the boss on the back side still appeared in the housing but was not drilled. The throttle and choke levers were forged steel with a unique marking.
The Holley double venturi was produced starting in early December 1927; the boss for the retaining pin was on the back side of the lower housing and the bowl only was marked H at the front of the housing ; the upper housing was marked H on the front of upper housing opposite the throat; original Holley carburetors shows the throttle and choke levers were nickle plated.
There is a excellent article in one of the latest "Restorer's" which lists all of the various progressive changes to the upper and lower housings.
One item which appears on all early carburetor lower housings is the brass removable needle seat for the GAV.
Ron
Ron in Quincy is offline   Reply With Quote
Old 08-12-2012, 03:01 PM   #7
James G.
Both Zenith made and Holly made carbs in 1928 were made with doubel venturi. Check the Cab book, Zenith Model "A" Carburetor Restoration Guidelines by Steve Paergeter.
James G. is offline   Reply With Quote
Old 08-12-2012, 07:52 PM   #8
SteveB31
SteveB31's Avatar
Also check out www.model-a.org
Very helpful site ONLY about Zenith Model A Carbs
Steve
SteveB31 is offline   Reply With Quote
Thread Tools
Display Modes
