Old 07-06-2021, 09:43 AM   #1
Bud
Bud's Avatar
Default Water Pump
I know the whole cooling system issue is broad and has been discussed many times. I looked recently for specifically how most rebuild their standard water pumps. I could not find much because it is buried under all the other cooling issues. What I do is set the end float on the water pump shaft to as low as I can get it (near zero), with the pump fasteners tightened. This keeps the shaft end float from reaming the packing out during running. I have run mostly water with rust inhibitor. I use the standard front bearing. I also run a plastic 6 blade fan. I have had no leaks and no problems. Please comment on how you set up your water pump. Please avoid a discussion on coolants (this is well documented in other threads). Please also not go into the various fan blade options as this has been discussed before. I know one can buy various leakless setups too, but I have never been confident of those designs myself. I am mainly interested in how you rebuild a standard water pump, i.e., what shaft you use, what end float you set, how you set it, and so forth. Thanks.
Bud is offline   Reply With Quote
Old 07-06-2021, 09:58 PM   #2
CWPASADENA
CWPASADENA's Avatar
Default Re: Water Pump
I use the stainless steel shafts and be sure to polish the area where the rear bushing and packing is.
I also set the end play as close to zero as possible with the pump bolted in place.
That's how I do it.
Chris W
CWPASADENA is offline   Reply With Quote
