Old 11-25-2016, 10:06 PM   #1
jim k
jim k's Avatar
Default 51 truck air cleaner bracket
Does anyone have a picture of the bracket that goes to the side of the oil bath air cleaner on a 51 F1 truck. My air cleaner has the cage nut for it but the bracket is missing and I don't know where it attaches to the engine or what the bracket looks like.
Thanks Jim K
Should have said it is a V8 Flat head I assume it gets a bracket since my air cleaner has the capture nut for a bracket
jim k is offline   Reply With Quote
Old 11-26-2016, 12:23 AM   #2
a36bonanza
Default Re: 51 truck air cleaner bracket
Is this for a 6 cyl. if so, I can send a picture tomorrow. One of the head bolts has a longer nut that allows a bolt from the A/C support bracket to attach to
a36bonanza is offline   Reply With Quote
Old 11-26-2016, 12:03 PM   #3
Bob C
Here you go.
Bob
Old 11-26-2016, 03:46 PM   #4
jim k
jim k's Avatar
Sorry guys I should have stated that it is a flathead V8
Old 11-26-2016, 03:57 PM   #5
Bob C
I've never seen a brace on the V8.
Bob
Old 11-26-2016, 04:13 PM   #6
jim k
jim k's Avatar
It's possible Bob that it doesn't I may have the wrong air cleaner it's the one that came with the truck and it fits the top of the carb. and clamps tight on it. I just thought since it has the capture nut on the side that it should have a support bracket.
Jim K
Old 11-26-2016, 04:33 PM   #7
Barry-ct
Barry-ct's Avatar
No support bracket on V8's. This one is correct for the V8.
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 11-26-2016, 09:18 PM   #8
jim k
jim k's Avatar
Thanks Barry my air cleaner doesn't look exactly like that but close. It will work its not going to be a show truck anyway just a real nice driver when its done.
Old 11-27-2016, 11:22 AM   #9
Barry-ct
Barry-ct's Avatar
as long as it works, that's what's important!
Barry
50 F-1
Old 11-27-2016, 05:38 PM   #10
jim k
jim k's Avatar
yea it works fine plus I did this to it with one extra mod to make the paper filter work
http://www.ford-trucks.com/forums/10...r-cleaner.html still looks stock
Old 11-27-2016, 06:12 PM   #11
glennsanders
glennsanders's Avatar
That air cleaner you could have been for F-6 are bigger truck
glennsanders is offline   Reply With Quote
