Old 08-14-2013, 07:35 AM   #1
jmeckel
jmeckel's Avatar
Default Autolite Heater Manifold Question
For those of you who have a Autolite manifold installed how do you change your condenser on a stock distributor? I tried to change mine this weekend and there is not enough room to get it out before it hits the waffle part of the manifold. Looks to me like the options are 1) cut a v shape in the waffle, 2) remove manifold to replace condenser, 3) pull distributor to replace condenser.
Jon
"If you choose to not decide, you still have made a choice!" RUSH
Don't tell me what you know..... Tell me what you have done.
jmeckel is offline   Reply With Quote
Old 08-14-2013, 08:24 AM   #2
Randy in Illinois
Randy in Illinois's Avatar
Default Re: Autolite Heater Manifold Question
Remove the heater cover, then loosen up the distributor lock screw. raise the distributor a 1/2 inch and you will be able to remove the condenser.
Randy in Illinois is offline   Reply With Quote
Old 08-14-2013, 01:15 PM   #3
Gold Digger
I mounted my condenser to the coil as I had problems with the condenser getting too hot and braking down.
Gold Digger is offline   Reply With Quote
