Old 08-09-2020, 02:13 PM   #1
revenski
Default Fuel line connectors- AN/JIC to IFF Questions
In following up my possible fuel line and/or fuel pump issues, I've been trying to simplify my current fuel line connections. I have a solid 1/4" - 45 degree flared line coming from the gas tank which has a 7/16-24 male connector. That needs to connect to the flex line going to the fuel pump which has a female JIC 1/2-20 connector with a 37 degree flare. Right now both the JIC and the IFF fittings are adapted to NPT and then connected with an NPT connector. I've been searching with no luck to this point to find a simplified connection. Do any of you know a better way to connect this 7/16" IFF male to the 1/2-20 JIC female? Or is there someone you might know of who builds customized fuel lines?
I'm attaching a photo of what I currently have. I don't consider it particularly good looking.
revenski is offline   Reply With Quote
Old 08-09-2020, 05:33 PM   #2
tubman
tubman's Avatar
Default Re: Fuel line connectors- AN/JIC to IFF Questions
I have no solution for you but I feel your pain.
Old 08-09-2020, 05:39 PM   #3
petehoovie
petehoovie's Avatar
Rube would be proud....
Old 08-09-2020, 06:03 PM   #4
tubman
tubman's Avatar
I saw it the first time, thank you. It says right on the post : "Attached Thumbnails".
Old 08-09-2020, 06:12 PM   #5
revenski
I appreciate the humor. Ford Barners have been great guys.
Old 08-09-2020, 06:20 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
This is what I would do.
Old 08-09-2020, 08:51 PM   #7
Charlie ny
Bob,
Why not cut the flare off the end of the tubing, remove the flare nut then slip on a Ford nut ( Edelmann 108400 ) and a 1/4" ferrule and connect your flex line to it....
the way Ford did ?
I just looked at your pump....next up tomorrow....it is the rare factory installed
design 1/2 20 inlet and outlet identical machining. Inlet accepts the male end of the flex line and seals on the angle. The outlet takes the 1/4" hard line and seals with a 1/4 ferrule and Ford nut.
Charlie ny
Old 08-09-2020, 09:21 PM   #8
revenski
I really appreciate both solutions. I was not clear on how Ford originally handled the connections. That is likely the way I will go. Thanks to both of you.
Old 08-10-2020, 06:21 AM   #9
revenski
https://www.fordbarn.com/forum/showt...+line+fittings
Having been given the identity of the Ford Edelmann nut used in the fuel lines, I was able to find this older thread of posts on its use:
Old 08-10-2020, 06:28 AM   #10
Mart
Mart's Avatar
Yeah, you're trying to reinvent the wheel. Use a ford nut and ferrule same as you use going into the carb.
Old 08-10-2020, 07:10 AM   #11
revenski
Got it. The carb is another matter.
AFTER CHECKING I SEE THAT IT'S NOT ANOTHER MATTER. ME BAD.
Old 08-10-2020, 08:11 AM   #12
Charlie ny
Bob,
Same everything...same Ford nut and ferrule used for Ford carbs and Strombergs....
trust us !
Charlie ny
Old 08-10-2020, 08:51 AM   #13
1948F-1Pickup
1948F-1Pickup's Avatar
Originally Posted by Charlie ny View Post
Bob,
the way Ford did ?
Charlie ny
Although I'm sure that works, interesting that Ford would use what is essentially a 45 degree ferrule as an interface between an SAE flare seat and a 37-degree seat.
I've seen people bubble flare (35-degrees) the steel tubing and then use that Edelmann fitting to connect to a JIC (37-degree) seat.
1948F-1Pickup is offline   Reply With Quote
Old 08-10-2020, 09:41 AM   #14
revenski
I'm looking for the simplest and most correct solution, and I seem to have it with the Edelmann nut and ferrule on the hard line from the tank to the flex line going to the pump.
Thank you everyone for setting me straight. And as Charlie said, my hard line from the pump to the carb already has Edelmann nuts and ferrules on both ends. I took it apart to check. I've looked at it in the past, but I guess it got recorded incorrectly in my memory.
Old 08-10-2020, 03:31 PM   #15
oldford2
oldford2's Avatar
cannot get simpler than original
oldford2 is offline   Reply With Quote
Old 08-10-2020, 04:45 PM   #16
petehoovie
petehoovie's Avatar
Originally Posted by oldford2 View Post
cannot get simpler than originalAttachment 438675
Old 08-10-2020, 07:20 PM   #17
oldford2
oldford2's Avatar
OOP's Don't want to change the topic, but,
Looks like my top oiler needs some MMO. 230 miles and used about 8 oz.
I love it.
That only gets into the intake/valves. I also put some in the gas to get it thru the carb.
John
Old 08-30-2020, 11:54 AM   #18
revenski
Thanks everyone. I had Charlie rebuild my original (factory installed) fuel pump and just installed that along with simplifying the fuel line connection by cutting the hard line from the pump and installing an Edelman Ford nut and ferrule. I squirted a little gas down the throat of the carb, and the truck pretty much started right up and ran without any leaks or problems. Time will tell, but this looks a whole lot better than what I had been experiencing previously regarding starting.
