Old 03-23-2023, 09:55 PM   #1
jgriffin
jgriffin's Avatar
Default Crankshaft pulley
Is there a difference between the solid crankshaft pulleys and the ones that have the 3 holes in them? Did certain years come with certain pulleys?
jgriffin is offline   Reply With Quote
Old 03-23-2023, 10:32 PM   #2
CWPASADENA
CWPASADENA's Avatar
Default Re: Crankshaft pulley
All original pullies were one piece cast iron with 3 "holes in them".
Chris W.
CWPASADENA is offline   Reply With Quote
Old 03-24-2023, 02:15 AM   #3
CarlG
CarlG's Avatar
Aftermarket "Billet" pulleys have no holes in them. I have a couple, including one of the dampers made in New Zealand.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-24-2023, 03:45 AM   #4
mercman from oz
mercman from oz's Avatar
Original (Background) and after-market (Foreground) Ford Model A Crankshaft Pulleys - jgriffin
Old 03-24-2023, 09:45 AM   #5
jgriffin
jgriffin's Avatar
Awesome! Thanks for the lesson everyone!
Old 03-24-2023, 09:54 AM   #6
rotorwrench
rotorwrench's Avatar
Steer clear of the zinc die cast pulleys. Most are likely two piece. The spoked hub solid cast iron is original but there are many reproductions out there of all types.
Old 03-24-2023, 10:26 AM   #7
Gene F
Gene F's Avatar
What are your thoughts on the harmonic dampener pulleys?
Gene F is offline   Reply With Quote
Old 03-25-2023, 05:25 PM   #8
CarlG
CarlG's Avatar
So far -- So good! I had to change the pulley anyway, so I reasoned "Why Not?" I've never had a problem fitting fan belts that others have reported.
Alaskan A's
Old 03-25-2023, 06:06 PM   #9
Gene F
Gene F's Avatar
Thanks CarlG.
Old 03-25-2023, 07:23 PM   #10
Synchro909
Synchro909's Avatar
I have one and the smoothness of the motor was immediately improved.
Growing old is inevitable. Growing up is optional.
Old 03-25-2023, 07:47 PM   #11
Gene F
Gene F's Avatar
Synchro...do you have a counterweighted crank, because I do?
Old 03-25-2023, 09:28 PM   #12
Synchro909
Synchro909's Avatar
I first put the balancer on an engine without a counterweighted crank - immediate and noticeable improvement. Later, I switched it to an engine with a counterbalanced crank. The improvement wasn't as pronounced but it was there. It's now on the latter engine where it has been for about 60,000 hard miles. I'm attributing the excellent life I have had out of that engine in part, to the harmonic balancer.
PS By life out of that engine, I mean life out of that rebuild. There will be more to come. It's only 0.060" oversize in the bores.
Old 03-26-2023, 03:16 PM   #13
Gene F
Gene F's Avatar
Synchro... Where did you order it? How did you get the old one off? I am thinking a couple 2-4s under it and give it a light tap. How did you get the new one on without damaging the thrust on the babbit inside? They say putting it on with an impact gun can strip the bolt hole....?
Now that my 12 month wannty is up, I sure would like to add one. I am hoping that this is THE LAST ENGINE I will ever have to put in my A. I have a bundle of money in the thing.
Old 03-26-2023, 03:18 PM   #14
Chris Haynes
Chris Haynes's Avatar
It looks like I will have problems for sure.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 03-26-2023, 04:46 PM   #15
Synchro909
Synchro909's Avatar
These balancers are available from the maker in New Zealand. From my rather poor memory, his name is Murray. Look at post 5 on this thread https://www.fordbarn.com/forum/showt...monic+balancer
The only downside to fitting one of these is that changing the fan belt can be a bit of a chore because they are thicker.
Thread Tools
Display Modes
