Old 03-27-2023, 09:59 AM   #1
TomIII
Default pinstripe masking-tape length
How much (length) tape would be needed to mask for striping 31 A SW std sedan (Murray)??
TomIII is offline   Reply With Quote
Old 03-27-2023, 10:17 AM   #2
Phil Brown
Phil Brown's Avatar
Default Re: pinstripe masking-tape length
Any good pinstriper will do it freehand, no masking tape used. If you're going to mask it off and paint a stripe then approx double the length of the stripe ( top and bottom ) measure the length of your planned stripe.
Phil Brown is offline   Reply With Quote
Old 03-27-2023, 10:48 AM   #3
ModelA29
ModelA29's Avatar
They make an easy to use tape for painting pinstripes - https://www.xcaliberart.com/product/...-stencil-tape/
ModelA29 is offline   Reply With Quote
Old 03-27-2023, 12:04 PM   #4
JayJay
That tape works great for straight lines, but where you have to make curves it gets very difficult (BTDT). And on the SW you need to make curves in your pinstriping. Best to get it done free-hand or use a pinstriping wheel.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
Old 03-27-2023, 03:33 PM   #5
ModelA29
ModelA29's Avatar
JayJay
Yep the curves are tough. They make different tape that easily turns - it's designed for doing flames. My car was done by hand many years ago and is getting thin in a couple spots. I've got a stripping wheel but I think I'll just find a guy with the talent to hand do the stripe and the eye to make the color match.
https://www.amazon.com/dp/B007VTQ9JE...2s9dHJ1ZQ&th=1
Old 03-27-2023, 04:43 PM   #6
dominiak
dominiak's Avatar
My first post. I know this is not how Ford did it. So many pinstripes are over the top of the finish coat, these are under the whole shebang. Light blue airbrushed then 1/16” wide tape over it. Dark blue next, followed by clear coat. A stripe that won’t ware off. Painted my Sport Coupe with original Ford colors but did the stripe s to last . Can’t feel them , smooth and protected. Cheers
File Type: jpg 589A3F87-5FD2-4306-BC2A-7F27E027666B.jpg (42.0 KB, 82 views)
File Type: jpg A5AD023F-674E-43C0-B84F-498EC8B957B1.jpg (44.7 KB, 82 views)
File Type: jpg D3BBB134-A67F-47EB-915D-D50D774CA743.jpg (49.7 KB, 92 views)
dominiak is offline   Reply With Quote
Old 03-28-2023, 08:07 AM   #7
old31
Dom, very nice job! A tank to be proud of.
What tape did you use?
old31 is offline   Reply With Quote
Old 03-28-2023, 10:57 AM   #8
rotorwrench
rotorwrench's Avatar
My hand isn't steady enough to do stripes with a brush so I buy the best quality 3M tapes that I can get to lay them out. A person can do a tape of the correct width as the marker tape and then butt the masking right up to the edge of the marker. When all the asking is applied, the marker can be pulled off just before applying the paint.
I always buy fresh new rolls of tape to lay out stripes and I get twice as much as I think I need to do the job. I always leave the edge tapes where I can peel them off without messing with the masking paper or plastic. That way I can peel the tape off the edge of the stripe while it's still wet. This allows it to flow a bit before it dries. It looks more natural that way. I pull the rest of the masking off after it's all dry.
Old 03-29-2023, 06:52 PM   #9
dominiak
dominiak's Avatar
I used 3M Fine line tape 1/16” wide. Airbrushed the light blue applied the tape( it’s very easy to bend around tight radius curves). Then sprayed the Lombardi blue. Remove the tape and then clear coat. The stripe is buried deep under the clear coat. I never saw this done before but I’m sure it’s not first time painters have used this technique.
File Type: jpg FCE1F362-8C28-4666-B539-E279B6C27D29.jpg (44.6 KB, 19 views)
Old 03-29-2023, 07:03 PM   #10
dominiak
dominiak's Avatar
Here’s a freehand stripe done by a local artist. Young person who’s very talented.
I didn’t want the freehand non stock striping on the car itself but thought the rear end could use a nice “ tramp stamp” or AKA some ink…..
File Type: jpg A5E9527B-AB93-4F5C-BD67-BBC83B500FEE.jpg (34.5 KB, 35 views)
