Old 04-12-2021, 07:53 PM   #1
Model A Ron
Model A Ron's Avatar
Default Speedometer Cable Good or Bad
Is the tab on my cable bad? I have a feeling it is but I would like your opinions.
Thanks
Ron
Model A Ron is offline   Reply With Quote
Old 04-12-2021, 09:33 PM   #2
jw hash
jw hash's Avatar
Default Re: Speedometer Cable Good or Bad
the tab looks good. what make you think it could be bad.
jw hash is offline   Reply With Quote
Old 04-12-2021, 10:50 PM   #3
Model A Ron
The ends of the tab are rounded and one end has a chip
Old 04-13-2021, 07:44 AM   #4
Big hammer
There's not much of strain, if it's well lubed!
get a bigger hammer tap done
Old 04-13-2021, 08:39 AM   #5
Patrick L.
Patrick L.'s Avatar
Looks good to me too. Does it fit OK ?
Old 04-13-2021, 03:25 PM   #6
Model A Ron
What should the cable be lubed with?
Old 04-13-2021, 08:25 PM   #7
McMimmcs
McMimmcs's Avatar
All the vendors sell the lube. You might want to order a new cable and put an end to your troubles while you’re at it.
McMimmcs is offline   Reply With Quote
Old 04-13-2021, 10:21 PM   #8
Model A Ron
I agree with you. I turned the cable by hand and it feels like its binding up inside so I ordered a new one. It was just $29 at Mike's and i hope it solves my problems.
Ron
Old 04-13-2021, 11:03 PM   #9
McMimmcs
McMimmcs's Avatar
Ron
I think that was a very smart move on your part, good luck ! Wayne
Old 04-16-2021, 04:14 PM   #10
Model A Ron
Wayne
I put on the new Cable on and the Speedometer works. I had a kink in the old one but the inner cable was good. Long story short you were right and thanks for the advise.
Ron
Old 04-16-2021, 04:28 PM   #11
McMimmcs
McMimmcs's Avatar
Wayne
Ron
You were right Ron, you just needed a nudge! We all need a nudge at times! Good luck, enjoy and be safe! Wayne
