Old 02-09-2021, 05:02 AM   #1
wasa 1940
Default Caged Nuts needed
Anyone out there know if any body is making 3/8 -24 square nuts and stamped cages. Roy Nacewicz, sold them, but he has past away.
wasa 1940 is offline   Reply With Quote
Old 02-09-2021, 05:08 AM   #2
GaryU.
GaryU.'s Avatar
Default Re: Caged Nuts needed
Check with Michael as he took over Roy's business. Here's a link to caged nut from his website. A call works great as he's one of the few that will actually take the time to talk to customers. https://thirdgenauto.com/product/new...-nut-assembly/
GaryU. is offline   Reply With Quote
Old 02-09-2021, 07:28 AM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
Bob Drake was selling different size square caged nuts at one time.
John
Old 02-09-2021, 07:46 AM   #4
V8COOPMAN
V8COOPMAN's Avatar
Like GaryU suggests above.....CALL and ask for MICHAEL Driskell at 3rd Gen! DD
(844) 327-5988
Click Links Below __
T5 W/TORQUE TUBE
Old 02-09-2021, 08:46 AM   #5
51 MERC-CT
51 MERC-CT's Avatar
If you are talking about the 'weld in' caged nuts that are available, then just tack welding on a standard nut should serve the same purpose.
Old 02-09-2021, 09:58 AM   #6
Kube
Kube's Avatar
C&G has them.
Old 02-09-2021, 10:38 AM   #7
woodiewagon46
McMaster-Carr has them PN 90955A120, 5 for about $13.
woodiewagon46 is offline   Reply With Quote
Old 02-09-2021, 11:22 AM   #8
35fordtn
35fordtn's Avatar
We have the correct ones Roy had. I am discontinuing them and would make you a smoking deal!
35fordtn is offline   Reply With Quote
Old 02-09-2021, 11:36 AM   #9
KiWinUS
KiWinUS's Avatar
Mike I’m in for some. What sizes do you have. Thanks. Cheers
Tony
Old 02-09-2021, 06:41 PM   #10
Angledrive
Angledrive's Avatar
Me too!
Angledrive is offline   Reply With Quote
Old 02-10-2021, 07:27 AM   #11
Tim Ayers
Me too.
Old 02-10-2021, 08:16 AM   #12
35fordtn
35fordtn's Avatar
1/4 5/16 3/8 and 7/16 although most all the 1/4’s sold out yesterday
Old 02-10-2021, 10:24 AM   #13
Zeke3
Zeke3's Avatar
I think I need 5/16 for fender attachment on an 37, will have to check.
Zeke3 is offline   Reply With Quote
Old 02-10-2021, 11:02 AM   #14
35fordtn
35fordtn's Avatar
Originally Posted by Kube View Post
C&G has them.
C&G only carries the more "Modern" cage nuts, as do we and everyone and they work just fine. But..... It's the authentic type that we are discontinuing and while I could be wrong I am fairly certain no one else carries them
Old 02-10-2021, 01:41 PM   #15
51 MERC-CT
51 MERC-CT's Avatar
Question, what type caged nuts are you speaking of? (weld on or clip in?}
Old 02-10-2021, 02:34 PM   #16
35fordtn
35fordtn's Avatar
Weld on I don’t think the acme style clip ins came about until 49
Old 02-10-2021, 08:26 PM   #17
DavidG
DavidG's Avatar
Michael,
One advantage of the original version is that it provides a little bit of wiggle room so that the nut can be moved around slightly making it easier to start the bolt in the nut, especially when attaching rear fenders. Judging from the C&G catalog image and others of the modern version, the nuts are fixed in place with tabs.
With either type it helps if the bolts are like the originals with a slight taper at the threaded end of the bolt.
Old 02-11-2021, 05:58 AM   #18
wasa 1940
Michael,
I am after 12 3/8-24nuts and cages for my 40 Tudor, m sons40 Delivery and grandsons 39
I am in Australia, have emailed you with Roy’s part no. For bolts 3/8 and 5/16 .
Old 02-14-2021, 09:26 AM   #19
hop up
hop up's Avatar
How many do you need as I have a few in my parts bin
Wanted flathead speed equipment Thanks
hop up is offline   Reply With Quote
