07-17-2020, 10:25 AM | #1 |
Axle taper degree
Do all 32-53 Ford rear axles have the same degree of taper into the hub?
If so, what is the degree? |
07-17-2020, 10:51 AM | #2 |
Re: Axle taper degree
No only thru 48. WAG 7 degrees?
07-17-2020, 11:36 AM | #3 |
True scoop....7 degrees! DD
07-17-2020, 11:40 AM | #4 |
Thanks for the info!
07-19-2020, 04:06 PM | #5 |
