Go Back   The Ford Barn > The Swap Meet > Wanted > Early V8
Old 02-12-2020, 04:24 AM   #1
5crm
5crm's Avatar
Default 1939 Ford standard heater and moulding parts
City: Bartow County
State: Ga.
I am looking for a 1939/1940 Ford/Mercury hot water heater motor, part#91A-18527-B, it has 4 wires, and is a 6 volt 2-speed reversible motor.
I am also looking for the defroster nozzles, part# 91A-18491-B, and heater hose brackets, part# 91A-15151 and 91A-15152.
I am
also looking for the "85" trim piece for the hood.
5crm is offline   Reply With Quote
Old 03-07-2020, 04:34 AM   #2
5crm
5crm's Avatar
Default Re: 1939 Ford standard heater and moulding parts
Found heater hose bracket part# 91A-15152.
Old 03-24-2020, 07:47 PM   #3
5crm
5crm's Avatar
Still looking.
Old 04-17-2020, 04:15 AM   #4
5crm
5crm's Avatar
Still looking.
Old 05-11-2020, 07:06 PM   #5
5crm
5crm's Avatar
Still looking.
Old 06-24-2020, 08:14 PM   #6
5crm
5crm's Avatar
Still looking.
Old 10-27-2020, 02:01 PM   #7
5crm
5crm's Avatar
Found heater hose bracket #91A-15151 and defroster nozzles part# 91A-18491-B.
Still looking for heater motor #91A-18527-B and "85" hood trim piece. Also looking for 1938/1939 clock bracket.
I am also looking for:
"Hot Water Heater Defroster Nozzle Deflector (For 91A Only)"
as shown in the links below in red outlines and underlined. I can't tell what the part number is in the parts list.
https://www.fordbarn.com/forum/pictu...ictureid=43185
https://www.fordbarn.com/forum/pictu...ictureid=43186
Old 11-05-2020, 01:54 PM   #8
5crm
5crm's Avatar
Also looking for a 1939 standard horn rod and a used original or NOS fuel gauge sending unit.
Old 11-05-2020, 11:49 PM   #9
5crm
5crm's Avatar
Found heater motor #91A-18527-B
Old 11-10-2020, 01:28 PM   #10
5crm
5crm's Avatar
Found:
1939 standard horn rod.
Fuel gauge sending unit.
One "Hot Water Heater Defroster Nozzle Deflector (For 91A Only)" part #78-18534, I still need one more.
I am still looking for:
The "85" hood trim piece.
The above mentioned defrost deflector.
Old 11-14-2020, 02:10 PM   #11
5crm
5crm's Avatar
Found defrost deflector.
I still need the "85" hood trim piece and the 1938/1939 clock bracket.
Old 11-21-2020, 11:07 PM   #12
5crm
5crm's Avatar
Still looking for the "85" hood trim piece and the 1938/1939 clock bracket.
Old 11-29-2020, 10:34 PM   #13
5crm
5crm's Avatar
