08-15-2015, 11:55 AM | #1 |
Ford Anglia/Prefect/Model A
I have 3 old prefect engines in various states of disassembly. But I don't have the distributor or Carb or Oil Pan. I was told the model A distributor would fit the Prefect. I think it is the 1.7L 10 hp model and is probably from 1948-50.
I would like to get one of these running again but don't know where to find parts. I have tried Small Ford Spares in the UK to no avail and others with the same result. This English engine and car were a scaled down model A ford. I had one in high school and it was a terrific car but need a lot of attention. I remember one time we packed in 5 adults and 6 small kids and went out for ice cream! Can anyone help? |
08-15-2015, 12:28 PM | #2 |
Re: Ford Anglia/Prefect/Model A
Try Berts in Denver, CO USA (See Sticky for information).
Also there were about 4-5 different varities of oil pans that were used on the Model A engine. http://www.plucks329s.org/studies/studies.htm Pluck Last edited by Steve Plucker; 08-16-2015 at 05:03 AM. |
08-15-2015, 12:53 PM | #3 |
Here's a few more to try in UK
http://www.belcherengineering.co.uk/ http://www.fsoc.co.uk/ http://poppartsplus.com/index.php/parts/electrical/ Have dizzy and recon carb listed. https://www.ford-aquaplane.co.uk/ If you want to hop them up a bit If that lot doesn't get you sorted then the things you are after turn up on eBay UK fairly often http://www.ebay.co.uk/sch/i.html?_od...&_sacat=131090 Cheers Juggs |
08-15-2015, 01:08 PM | #4 |
Thanks for all the good information.
08-16-2015, 12:43 AM | #5 |
The Prefect distributor was a common replacement for the A one as it had centrifugal advance, so no levers and things.
Belcher Engineering looks interesting: http://www.belcherengineering.co.uk/...tion/index.php |
08-16-2015, 06:32 AM | #6 |
http://www.angliaobsolete.com Last edited by leakers; 08-16-2015 at 07:34 AM. |
