Old 04-24-2014, 08:11 PM   #1
Will Ziegler in LI NY
Will Ziegler in LI NY's Avatar
Default Snap-On spring spreader
Need some help.
Does anyone have any info on the snap on s9023 spring spreader?
The snap on 1936 and 1937 catalogs I have seen on line all refer to it having a ball bearing ratchet assembly to take the thrust. I do not see any bearings in the one I just got. Am I missing something?
Thanks,
Will
Will Ziegler in LI NY is offline   Reply With Quote
Old 04-26-2014, 01:21 AM   #2
KR500
KR500's Avatar
Default Re: Snap-On spring spreader
Will, I believe the thrust they are referring to is a bearing like the Model A king pin bearing. I have the 9023 spreader but no C shaped part for rear spring. The ratchet is just a reversible ratchet. The thrust bearings are between the tubes and screws.
KR500 is offline   Reply With Quote
Old 04-26-2014, 01:39 AM   #3
Mike V. Florida
Mike V. Florida's Avatar
http://www.freepatentsonline.com/1898121.pdf
Look at the right hand side of the first page, look for #27
Here is is in use;
http://www.fordgarage.com/pages/snap...ngspreader.htm
Old 04-30-2014, 05:57 PM   #4
Mike- thanks for the link to the patent it shows exactly where the bearing is in the nut.
KR500- I just got the c shaped part to go over the rear end center section. You are right, the bearing is just like a king pin thrust bearing. Mine was so dirty and nasty that it did not move at all. I took it out and after a good soaking in lacquer thinner I was able to free it up.
I will post some photos after I finish cleaning it up.
Will
Thread Tools
Display Modes
